Insulation value of dense pack cellulose
| Posted in General Discussion on November 27, 2001 10:45am
I know there’s a lot of material to search on, but it will take me forever to find the answer to this question.
I know the value for loose fill but what R-value will cellulose packed to 3 or 3.5 lbs/cu.ft give me?
As usual, thanks for your help.
David
  1. Mongo_ | Nov 27, 2001 10:49am | #1
    Your mileage may vary, but figure about 3.7 or so. An additional and often overlooked benefit of dense-packing is the air sealing.
    1. Mike_Smith | Nov 27, 2001 03:20pm | #2
      *3.7 is generally accepted..which will give you R-13 for a 2x4 wall .... same as the nominal value for high density fiberglass with out teh edge leaks
      1. David_Crick | Nov 27, 2001 08:41pm | #3
        *Thanks guys. I did do a search late last night using "mike smith" as key words because I know you often get into detail about energy walls. You're such a prolific poster it took me an hour to find the same figures. Thanks again. David
        1. Gene_Leger_ | Nov 27, 2001 10:45pm | #4
          *David, et al/ The Cellulose Insulation Manufacturers Association (CIMA) has a toll free phone line: 888.881.CIMA. GeneL.
  2. David_Crick | Nov 27, 2001 10:45pm | #5
    I know there's a lot of material to search on, but it will take me forever to find the answer to this question.
    David
