hung a new door in my house, 3 hinge solid wood, weighs 60 pounds or so. It was NOT prehung, I had to add a center hinge since the previous doors where hollow pieces o’ garbage, and I thought 2 hinges wern’t enough to hold it. Now, the price I’m paying for not doing it right (by installing a prehung door) is that when the door is about 1/2 way open, it slowly continues to open itself all the way open. So, what should I do ? Adding shims behind one of the hinges or what ?
thanks !
Kirk
Listeners write in about earning trade-work merit badges and ask questions about radiant cooling, indoor air quality, and radon-control systems.
How to Install Cable Rail Around Wood-Post CornersRelated Stories
Check to make sure the hinge leg of the jamb is plumb. The extra weight of the solid door will show up this problem even if it didn't affect the hollow-core.
thanks for the tips, I'll give them a try.
Kirk,
Both of the previous respondents are correct in their assumption that the door jamb (hinge side) is out of plumb...if the door was hung correctly on the jamb. Keep in mind that it is equally possible that the door was not hung correctly (no offense here) and does not flush out with the jamb from top to bottom when closed. The first thing you should always do prior to hanging a door in an existing jamb is to check the plumb on the jamb legs in both directions, check the level at the head and at the floor, and look the existing door over for any tell tale signs of a problem... incorrect reveals on the head or jambs, out of square cut at the floor etc. Hanging a new door in an existing jamb is half science, half art and simply ripping it out and installing a prehung will not solve all of the potential problems. Frequently in old homes we run into situations where the wall itself is significantly out of plumb and we must cheat the entire door assembly and then deal with it when trimming to camouflage a problem.
So to return to your original problem, get out a level and check it out.
Bill
Bill,
Joe,
Did not want you to think I was being a nit picker here, it is just that you never know the capabilities of the individual who asked the question. An experienced carpenter would realize what was happening before the door stopped moving the first time. My point being, if the individual who hung this door was not expereinced enough to understand why this was happening in the first place, they "may have" been novice enough to make a different mistake as well, such as not hanging the door correctly in the existing jamb. More than enough said...and it's nice to now that after all this time that Newton still had it right.
Bill
Bill,
Edited 6/6/2002 6:04:42 PM ET by J Fusco
We all need stability in our lives.
So it's reassuring to know that gravity still works.
The jamb is not plumb.
