Is this going to cause a problem?
barcode | Posted in Energy, Heating & Insulation on November 30, 2007 10:56am
On behalf of the lurkers, thanks to all who take the time to post here.
I have a question.
I want to better insulate my shop
Wall assembly from inside to out is…
paint,1/2″GWB,3mil vapour barrier,F.G Batts & 2×6, 1/2″ sheathing, tar paper.
No siding yet.
I was considering adding ridgid foam (XPS ?) then strapping  and then the siding.
Would this create a problem as far as creating a second  vapor retarder?
I am in the pacific north west so think RAIN    then some more Rain followed by showers, then more rain.
I have searched the archive with little success but if anyone can help it would be appreciated.
  1. DanH | Nov 30, 2007 03:25pm | #1
    So long as the inside vapor barrier is tight that arrangement wouldn't cause problems in any non-tropical environment. In the PNW, if you're sufficiently coastal that you rarely see temps into the single digits, that goes double -- condensation inside the insulation is really only a problem below 10F or so.
    In the PNW, though, you definitely want the stapping over the outside foam (and maybe over a layer of housewrap) before siding, to create a rainshield drain plane.
    1. barcode | Nov 30, 2007 06:47pm | #2
      another question?
      Do I need to remove the existing tar paper? or can it be left in place?
      What is the best way to attach the ridgid foam?
      Do I need tar paper over the foam?
      And the plot thickens
      The siding I have is 1x8 shiplap (vertical) so I was going to attach the stapping horizontaly.
      Would this affect the drain plane behind the siding?
      Suggestions?
      1. DanH | Nov 30, 2007 08:34pm | #3
        My main suggestion would be to not use vertical shiplap in a rainy environment. If you do you should probably use one of the available rainshield products.
        1. barcode | Nov 30, 2007 11:19pm | #4
          Funny, that's what I thought too.
          but when you get materials for next to nothing. you gotta compromise.
          and it matchs the house.
          now whats the best way to attach building paper to this stuff?
          I have images of Huge dents from a hammer tacker?
