is this idea too bizarre??
roxanna | Posted in General Discussion on November 2, 2004 07:23am
Have just had replacement windows and sliders put in.  The house is a contemporary Tudor-style with fairly dark-stained interior trim around the doors and windows.  The new windows and doors came unfinished, with the idea to have them stained to match the present dark stain.  However, I find that I am liking the lighter (pine) color as it is so much brighter.  Here’s the question:  could I keep the windows, etc. stained very pale (really just a sealer) with the casing around them still dark??  This would give a two-tone effect which doesn’t follow the usual “rules”.  On the other hand, who decided that casing needs to be the same as the sash?  I have been trying to find photos of this done somewhere and have had no luck — is that reason enough to give up on the idea?….  HELP, please!
Edited 11/2/2004 8:16 pm ET by Roxanna
    lindenboy | Nov 03, 2004 09:48pm | #1
    There are no rules.  If you like the look, then keep it.  You don't need pictures when the installation gives you the example.
    j
    1. roxanna | Nov 03, 2004 10:28pm | #2
      thanks for the reply.  it's just what i was hoping to have confirmed!  i shall now "bravely go where no one has gone before"....
        lindenboy | Nov 04, 2004 04:36pm | #3
        Now that I've had a few minutes to think about what I just said (sometimes it's easy to forget how one's responses come across in this format) I would add a few items for clarification:
        1.  You may want to investigate using a semi-transparent stain product without using a permanent top coat (such as polyurethane) in case you want to re-stain the windows with a darker color later.  You mentioned a light colored sealer, which seems like it would work fine, but perhaps you should take the "installation" portion of your idea to a paint shop for get input from someone with a more technical persuasion.
        2.  You may find that realtor's shy away from suggesting stark changes to a "typical" styles, should you find yourself selling in the short term.  It's one thing to simply not care (my general theory), but it's another if you could be planning a move in a few years and have a selling problem with a "different" looking facade.
        The finishes will require maintenance eventually, and it's always easy to re-stain the wood dark to match the surrounding area the next time you 'paint.'
        hope this helps!  good luck!
        j
        1. roxanna | Nov 04, 2004 10:50pm | #4
          I appreciate the further advice.  Will definitely check out your first paragraph thoughts at the Sherwin-Williams store.  They are used to my queer questions, since we just had the exterior painted this summer.
          As to problems with potential buyers not liking the way I do things -- I fully intend to be carried out of this house in my coffin (but not for a long time, please!!) -- no other way will this place be on the market!!  I do like what you suggested about using semi-transparent stain etc. in case I decide later to go back to the dark --  a good idea.  The rest of the house (so far) is keeping the dark Tudor-color stain around all the windows and doors inside.  It's not a bad look, tho a bit dreary.  The window trim and door casings are simple ones, rather like a plain picture frame, so I think my idea will not look too weird.  We shall see... Anyway, thanks so much for the replies!
A Practical Perfect Wall
  • The New Old Colonial
