Brian, Try some grease under, on or around your pals driver side car door handle. Its also not very nice, but some of the same grease-just a dab, on the end of those air tool connections. Hmmm, been there and done that too.
If you've got a phone around try putting a dab of shaving cream on the reciever (where the ear goes); gently hang it up & then call the number & let your pal answer it!
Change the fob (or the keys) on the key rings so none of the keys are the ones expected!
Some gardening areas sell a long-lasting nastey sticky stuff called "Tanglefoot" in a small toothpate type tube. Intended use is spreading around the base of trees to keep ants and other crawling bugs from climbing up.
Has multiple clandestine uses. More effective than grease, and harder to get off. For the mean only.
*Saran wrap over the toilet bowl. those who stand get sprayed. Those who sit get stuck.
April fools and the http://www.My brother and myself just set up the owner of our local building supply center. He just happens to be getting married soon. http://www.pointroberts.com/loren
What are friends for!Comments to [email protected] until wednesday
Pat
I'll start the ball rolling..and who knows what else. Before leaving work, I covered the "throne" with WD40.....my wife would be the next to use it!! Remember that old song....Slip, sliding away.......
*In the dorms, we'd put goldfish in the women's toilets - no way would they flush the poor little fish. Peanut butter around the rim with multi-colered mini jawbreakers imbedded in the peanut butter adds some color and visual interest.
