Joining face frames. . . sigh
Biff_Loman | Posted in Construction Techniques on February 21, 2008 04:03am
All right, so they want a face frame vanity. Haven’t built anything with face frames before, just frameless.
So, for joining the frame stock, I do NOT have:
– Kreg jig
– Dowel jig
– Mini biscuit joiner
– Any setup for making mortises and tenons.
You’re all going to tell me to buy a Kreg jig, aren’t you.
    McDesign | Feb 21, 2008 04:12am | #1
    No problem.  I did my kitchen before I had any of that.  Just careful fitting, use those flat-under-head Kreg-like screws; screw it together, countersink the holes first with a 3/8" Forstner bit, and make some plugs out of your scrap that matches the grain wherever you put a screw.
    Or you could do that whole mortise and tenon Japanese Woodworker thing, if you've got the time.
    I still contend that the whole Japanese tradition of intricate joinery would never have happened if they had discovered drywall screws.
    Gene_Davis | Feb 21, 2008 04:23am | #2
    3/8" or 8mm dowel center-marker plugs, a bit, your corded or cordless drill, a little glue, some dowels, and you are in bid'ness.
    Your face registration might not be as good as it could be with a nice biscuit or pocketscrew setup, but what the heck, sandpaper is cheap.
    You do have a nice little RO sander for leveling up and prepping for the finish, right?
    "A stripe is just as real as a goddamn flower."
    Gene Davis        1920-1985
    Edited 2/20/2008 8:23 pm ET by Gene_Davis
    1. Biff_Loman | Feb 21, 2008 04:25am | #3
      ROS? That I have.That method is tight. Really, that's awesome. . . sometimes I have an irrational bias against having unnecessary steel inside wood. But I can't be bothered with fancy joinery. That's the ticket.
      Edited 2/20/2008 8:26 pm ET by Biff_Loman
        Gene_Davis | Feb 21, 2008 05:10am | #6
        Steel inside wood?
        Only for the marking.  Drill two holes in part A, insert marking dowel pins, index piece A to mating piece B, press together, and voila!  You have successfully marked for where to drill into piece B.
        Pull those two marking dowel pins and re-use them to mark all your holes.
        These spiral-grooved preglued dowels work pretty neat, but most of the places that sell them, want to sell you a few thou at a time.
        1. Biff_Loman | Feb 21, 2008 05:27am | #7
          Hmm, I didn't put that right. I got it. . . I was just trying to say how much I liked your idea BETTER than using pocket screws.I don't like fancy joinery, so I like the idea of dowels. I'll probably do exactly as you suggest.
          Edited 2/20/2008 9:30 pm ET by Biff_Loman
          Edited 2/20/2008 9:31 pm ET by Biff_Loman
          1. vanderpooch | Feb 21, 2008 05:36am | #11
            Biff,Dowels will work fine. They did it for years and years. As usual I agree with Jim, no carpenter will regret buying a Kreg jig. You don't have to get the whole $150 setup. Start with the little single hole jig and a bit. You're only out $20 if you decide you never want to use it again. But I'd bet against it. Really, dude, buy it.http://www.amazon.com/Kreg-MKJKIT-Mini-Jig-Kit/dp/B00065WPP2/ref=sr_1_15?ie=UTF8&s=hi&qid=1203561345&sr=1-15- KitTechnique is proof of your seriousness. - Wallace Stevens
          2. Biff_Loman | Feb 21, 2008 05:38am | #12
            Consider me convinced. I will swing by Art's Tools tomorrow morning prior to the job site.
          3. dovetail97128 | Feb 21, 2008 06:41am | #14
            If your going to use dowels spend a few bucks for a jig. Accuracy in drilling perpendicular is everything.
            Buy a "spur" bit as well, drills clean and straight .
  3. jimblodgett | Feb 21, 2008 05:04am | #4
    If you're a carpenter buy a Kreg jig.  You won't regret it.
    I'll eat your peaches, mam.  I LOVE peaches!
    1. Biff_Loman | Feb 21, 2008 05:32am | #9
      Carpenter? No.
  4. fingers | Feb 21, 2008 05:08am | #5
    I'm not going to tell you to get the Kreg Jig but suggest that you think about buying the Kreg mini jig. I think you can pick up the single jig, bit and stop collar for about $20. It will do everything the bigger jig will do only not quite as fast.
    I'll bet that if you get it, you'll find all sorts of other uses for it and then you'll break down and buy the whole K-3 kit or whatever they call it.
    1. Biff_Loman | Feb 21, 2008 05:33am | #10
      $20? Geez. No question - I will buy one of those, for the hell of it.
    2. fingersandtoes | Feb 23, 2008 09:35am | #16
      The Kregg mini jig is great. Cheap (even here in Canada) and small too. I keep mine in a zip lock sandich bag. My only beef is that the instructions are such tiny print I haven't been able to read them since I was 40.
  5. MikeSmith | Feb 21, 2008 05:32am | #8
    did a lot of face frame, back in the day...
    glue & pre-drilled finish nails
    but i'd still buy the kreg.. you won't regret it
  6. DonCanDo | Feb 21, 2008 06:16am | #13
    This just might be one of those times that a Harbor Freight tool could be useful.  They have a biscuit joiner for $60 that works pretty well and you'll find many other uses for it.
  7. User avater
    JeffBuck | Feb 21, 2008 08:44am | #15
    1 1/2" stock?
    like Mike said ... drill and use 2.5 or 3" screws.
    or ... like Gene said ... dowels are cheap and easy.
    or ... U got a table saw?
    half lap joints
    access to a radial arm saw ... half laps are even easier.
    and strong as hell.
    cut them tight and clamp ... no steel.
        Buck Construction
     Artistry In Carpentry
         Pittsburgh Pa
    1. Biff_Loman | Feb 23, 2008 02:50pm | #18
      Half lap, eh? Niiiiiiice. That's a great idea.
      1. TomT226 | Feb 23, 2008 02:55pm | #19
        Got a RAS or a TS?  Router table.  M&T is easy, and I've got a system that's fool proof, and you don't have to buy anything else...
  8. Hudson Valley Carpenter | Feb 23, 2008 02:34pm | #17
    You're all going to tell me to buy a Kreg jig, aren't you.
    You psychic or somethin' ?   I bought the $20 mini version a few months ago, after reading the raves about it here.
    The only other tool required is a small bar clamp, unless you wanna go for the special visegrip, which is no big advantage, IMO.
    I use a small bar clamp with rubber/whatever covered jaws which squeeze down very nicely to align the pieces being joined.
    Once you've used the Kreg, it's pretty obvious how superior the joint is and how simple it is to get everything perfectly aligned.
    Edited 2/23/2008 6:47 am by Hudson Valley Carpenter
  9. Waters | Feb 23, 2008 06:45pm | #20
    Kreg.
    You can buy the little one for 25$
    I use it for lots of other things too...
    "Research is what I'm doing when I don't know what I'm doing..."
  10. IdahoDon | Feb 24, 2008 12:35am | #21
    If your time is worth anything more than $5 an hour get a kreg jig.  I shake my head watching a finish carp or cab. maker trying to use other methods, "because that's the way I've always done it."
  11. User avater
    PeteDraganic | Feb 24, 2008 01:17am | #22
    A trick I've used is to cut slots in the joinery area with a table saw and then insert plywood spines for biscuits.  This may or may not work for you but it is worth considering.
    I refuse to accept that there are limitations to what we can accomplish.        Pete Draganic
Behind the Scenes of a Concrete Batch Plant
The batch plant is your partner in getting high-quality concrete on your job site.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
