Joist load
mattt19 | Posted in General Discussion on March 8, 2008 03:09am
I’m installing a whirlpool bath in my bathroom. The floor is required to support 80lbs per square foot. Is there a way to calculate what load my joist will carry? The tub runs parallel to the joist. There are three joist that will carry the load of the tub. They span 8′. The first joist is a true 2by6 with a 2by6 sistered to it. Next are two 2by6’s sistered together and finally a lone 2by6 (true). The flooring will be 3/4 ply. The joist feel stiff and don’t flex when I bounce on them. Will this hold my tub?
  1. Riversong | Mar 08, 2008 03:17am | #1
    Assuming the spacing is 16" o.c., it would require KD 2x10s, or double KD 2x8s to carry 80 psf live load plus 10 psf dead load over an 8' span.
    None of the current joists are sufficient for that load.
    Riversong HouseWright
    Design *  * Build *  * Renovate *  * Consult
    Solar & Super-Insulated Healthy Homes
    Edited 3/7/2008 7:18 pm ET by Riversong
    1. mattt19 | Mar 08, 2008 04:45am | #2
      Would putting in a beam under those three joist, reducing the span to 4' , take care of the problem?
      1. peteshlagor | Mar 08, 2008 04:48am | #3
        What would that beam sit on?
      2. Riversong | Mar 08, 2008 04:56am | #4
        Absolutely, as long as the forces are "grounded" properly to footings that can support the load.
        Design *  * Build *  * Renovate *  * ConsultSolar & Super-Insulated Healthy Homes
        1. mattt19 | Mar 08, 2008 05:26am | #5
          I was planning on pouring two pads with concrete piers on top to support the beam. The house is post and pier construction (1913). The existing pads are about 2' square and 4" deep. A 4by4 post sits directly on the concrete and supports a 4by4 beam.
          How would I determine the depth and size of the pad I would need to pour? The floor of the bathroom is pulled up so getting access isn't a problem. What is a problem is the number of pipes in this area. It's where most of the plumbing in the house joins the main line.
          1. Riversong | Mar 08, 2008 07:58pm | #6
            Can you post a picture of the support system?
            A 4" thick pad is very thin, particularly if it's not steel reinforced.  What is the spacing of the posts?  Is this a crawl space foudation?  What supports the perimeter of the house?
          2. mattt19 | Mar 08, 2008 08:30pm | #7
            Hi Riversong,The house was built in 1913. It has a perimeter foundation with a crawl space. Half of the foundation is the original foundation and half was replaced eight years ago. The interior is supported with post sitting on concrete pads. The construction of these varies. Some are the original post which consist of the concrete pad, a wood pad ( approx 2" by 6" by 6") and then a 4"by4" post on top of that. The post supports a 4"by4" beam that runs the length of the house. Beams are spaced about eight feet apart. The original concrete "pads" vary greatly in size. From what I can determine a hole was dug and then filled with concrete, leveled and then the post set on top of this. These pads are about 16" across and 12" to 16" deep. As far as I know there is no rebar. Some of these were replace with newer pads. These are 24" square, approx 4" deep and are reinforced with rebar. A number of the original post and wood pads were replaced due to insect damage. These were replaced with concrete piers and pressure treated 4" by 4" post. This was placed on top of the existing pads.
            I'll see if I can post a picture of the post.Thanks for the help.Matt
          3. Riversong | Mar 08, 2008 08:54pm | #8
            The pad size is dependent on total load supported and the weight-bearing capacity of the soil.  But, absent that information, a 20" square by 8" deep pad should be more than adequate to support a 4x4 post.  Rule of thumb is to have the depth equal the distance from post to edge, so that a square cross-section is maintained beyond the post on all sides.
            And reinforce with a tic-tac-toe of 1/2" (#4) rebar.
            Edited 3/8/2008 12:55 pm ET by Riversong
          4. mattt19 | Mar 08, 2008 10:01pm | #9
            Thanks for the info. Looks like I have some digging ahead of me.I have a question regarding the joist span. I have a IRC chart that shows the allowable joist span for doug fir #2 at 9'9" for 40 spf for a live load. Does doubling the joist double the live load it can carry?Thanks again,Matt
          5. Riversong | Mar 08, 2008 10:31pm | #10
            What size joist at what on center spacing? How do you know your joists are doug fir #2?
            If you mean sistering two identical joists together, yes.
            But those tables are for specific graded lumber species and are maximum (not optimal) allowable spans.
          6. mattt19 | Mar 09, 2008 03:10am | #11
            Hi Riversong,The spacing is 16" oc. I installed the new joist, they're grade 2. I assumed that the old joist, being old growth fir, was better (stronger) than a new 2 by 6. Did they grade lumber in 1915?
          7. Riversong | Mar 09, 2008 03:57am | #12
            Sure.  This one's good. That one's junk...
          8. mattt19 | Mar 09, 2008 06:36am | #13
          9. mattt19 | Mar 12, 2008 06:51am | #14
            I've dug the holes and am ready to pore the pads, but I'm wondering if I might have a problem. Two months ago I discovered the drain pipe for the sink and dishwasher was broken. It took a week before I noticed. When I went into the crawlspace I discovered a mini lake. I pumped it out and have been running fans to circulate the air and dry it out. The surface dirt is dry, but when I dug down several inches the soil was still moist. The soil is clay. I'm concerned that when it eventually dries out the soil will shrink taking the pads,post and beam with it. Should I be concerned about this?
          10. BillBrennen | Mar 12, 2008 08:12am | #15
            Matt,How moist? In most parts of the country the soil is always moist a few inches below the surface. If what you see is the "normal" moisture, then it will likely remain that way for the life of the house. If the clay is really soggy, you have a problem. Further digging may remedy it.Dig some test holes in your yard, or in a part of the crawl that did not flood, to establish a baseline for "normal" moisture levels in the soil where you are.Bill
          11. mattt19 | Mar 12, 2008 11:13am | #16
            Hi Bill,I wouldn't call it "real soggy" but the soil is moist enough that I can ball it up like a snowball. I'll dig a test hole in a part of the crawl space that wasn't affected by the flooding to see what the moisture in that soil is like. I'm in Los Angeles, prior to this year we went almost an entire year without any rainfall so I'm inclined to believe that the amount of moisture I'm seeing isn't normal.Would I be able to install the beam but not attach it to the floor joist, then once the crawl space has completely dried out check the beam, shim it if necessary, and attach it to the joist?
          12. BillBrennen | Mar 13, 2008 08:27pm | #17
            Matt,Yes, you could do that. You might want to connect the beam to the joists temporarily with truss clips so it is restrained laterally but can move up and down. This also allows your beam to shrink. I would still favor digging past the wetness to stable soil and pouring on top of that. Screw jacks are another option to consider, as they would allow you to compensate for settling of the pad and/or shrinkage of the beam.I live just 100 miles south of you, and the soil is damp in my crawlspace, but not as wet as you describe.Bill
          13. dovetail97128 | Mar 13, 2008 08:31pm | #18
            Turn that board upside down and the knot is no problem as long as it is tight. It would be in compression.
  • Drafting the 2027 IRC
  • Get a Grip
  • Wire- and Finger-Safe Cable Stripper
  • Two Ways to Test Windows
