I plan on replacing a couple of 2-prong recepticles in a building that has knob & tube wiring. The wiring looks fine. The question is that I recall reading or hearing somewhere that instead of replacing a 2-prong plug with another 2-prong that instead the electrical code allows the installation of a GFI recepticle. I’d appreciate any feedback on whether this is code approved. I’m in the San Francisco Bay Area.
Regards,
Tark
Bill Hartmann is very knowledgeable about matters electrical. See his response on the subject from a recent thread.
http://forums.taunton.com/tp-breaktime/messages?msg=99901.6
Yes, the NEC has allowed that since at least the 99 NEC. But I did not discuss in the thread that the OP linked to.
You can also replace downstream receptacles with grounding type if protected with a GFCI.
No connections are to be made to the ground teminals.
And the receptacles are suppose to be labled No Equipment Ground.
But you realize that replaceing an ungrounded receptacale with a GFCI will cause cancer, but only in California. But so does installing an ungrounded receptacle. Or a grounded one.
Thanks Bill!
