Kitchen floor demolition
JonLindsay | Posted in Construction Techniques on February 24, 2007 12:21pm
I am about to renovate a 25 year old kitchen (approx 15′ x 15′).  The existing floor is large 12″x12″ ceramic tiles (with thinset) on a 3/4″ ply substrate which is screwed and glued to the 1/2″ underlayment.  This made for a very solid crack-free tile floor but the owner (wife) now wants a hardwood floor installed in the new kitchen.  Any suggestions for removing the old tiles and subflooring.  Need to get down to 1/2″ (7/16″ CDX?) for the new hardwood floor, so should I plan on cutting down to the floor joists?  Basement below is unfinished.
Jon
  1. woodroe | Feb 24, 2007 03:06am | #1
    Take it down to the joists. You will never get the 2 layers of plywood apart. Use 3/4" plywood subfloor for the hardwood. 1/2" is not adequate.
    1. JonLindsay | Feb 24, 2007 04:27am | #2
      Thanks Woodroe, Rats, hoping you had a magic cure.  But, cutting out the floor is not impossible with the right crew.  A new 3/4" subfloor will require a slight but noticeable threshold.  You suggest that for additional stability/stiffness I suppose?
      Jon
        EricPaulson | Feb 24, 2007 05:04am | #3
        The need for more than 1/2" under 3/4" hardwood is certainly arguable.
        Ask the poster why 1/2" is inadequate.[email protected]
        1. woodroe | Feb 27, 2007 05:49am | #8
          The Hardwood Fooring Institute does not recommend using less than a 5/8" plywood subfloor. Not less than 3/4" if the subfloor is OSB.
            EricPaulson | Feb 27, 2007 05:55am | #9
            That's all well and fine.
            And 100's of 1000's of homes have been built with 3/4 HW over 1/2 ply and have not experienced any problems because of it.
            What does the Hardwood Flooring Institute have to say about that?[email protected]
            WHICH content will be free, of course; WHICH content will require registration; but WHICH content will be available only to members of FineHomebuilding.com.???
          2. woodroe | Feb 28, 2007 02:53am | #10
            "What does the Hardwood Flooring Institute have to say about that?" I don't speak for them so I don't know. I'm not inclined to do more research into the reasons for their recomendations either. None of the installers we use will install over 1/2". I'm guessing one reason has to do with the nail holding power of the 1/2" material.
            EricPaulson | Feb 28, 2007 03:00am | #11
            That's why we try to hit the joists with the nails![email protected]
          4. woodroe | Feb 28, 2007 03:51am | #16
            Eric, you can install floors however you want, but 10"-12" between nails is recommended and 8"-10" apart is preferred according to the standards of the industry. These standards are developed by the industry to eliminate problems, as well as to create a standard for a proper installation. If you ever have a homeowner complain about a squeaky floor, or one that shows signs of buckling in humid weather, and it is found to be installed in a manner not recommended what are you going to tell them? As the installer or contractor you would most likely be the one to warranty the floor, why would you take the risk of doing a substandard installation and it coming back to bite you later?There are a lot of guys who installed windows "the way they always have, (and I never had a problem)", and all of the sudden the houses are rotting away because of leaking problems. In our litigious society it is not wise to play fast and loose with installation proceedures for anything.
            EricPaulson | Feb 28, 2007 05:15am | #17
            Thanks. In 30 years I've never had any problems with the floor I have done or with the floors my subs have done. Guess we'll just keep doing that way.[email protected]
          6. AllTrade | Feb 28, 2007 03:36am | #14
            100's of thousands? i have yet to see one in all my years. Actually it would not pass the framing inspection here.
          7. User avater
            EricPaulson | Feb 28, 2007 03:49am | #15
            Well here in NY it would........or used to.
            I was around for the boom in the early eighties. Everything got half inch. EVERYTHING.
            This was not a one time shortcut, my imagination or a hallucenation. It's general practice.
            Ok, tens of thousands...........thousands??[email protected]
          8. MikeHennessy | Feb 28, 2007 03:08pm | #19
            "And 100's of 1000's of homes have been built with 3/4 HW over 1/2 ply and have not experienced any problems because of it."
            I'll go one better -- in my house, the entire second floor has no subfloor at all. Just 3/4" HW nailed right to the joists. (I've seen this in several other houses built in the '30s as well.) Worked OK so far, but I'd never do it.
            Mike HennessyPittsburgh, PA
          9. BryanSayer | Feb 28, 2007 07:25pm | #21
            I was going to say the same thing. I used to live in a neighborhood built during the depression, and we didn't have ANY subfloor. Long leaf SYP directly on the joists.No sheathing underneath the siding either.
      2. sharpblade | Feb 24, 2007 06:58am | #4
        Please tell us why. Old floor is 1/2" +3/4" ply + ~1/4" tile = 1.5 inches
        new floor with 3/4" ply + 3/4"  HW strips = 1.5 "
        => same height
        1. finnegan | Feb 24, 2007 07:06am | #5
          How about floating an engineered wood floor right over the tile?
          1. Stilletto | Feb 24, 2007 02:40pm | #6
            Probably not a good idea,  another layer of floor will probably lock the dishwasher into place.  No way to service/remove it without peeling the floor up or taking the countertop off.
            Also he may have to cut doors down that lead into the kitchen.
        2. JonLindsay | Feb 28, 2007 06:46pm | #20
          The slight threshold would be due to the fact I will be removing the existing tile and subflooring (as you say ~1.5").  But this is a renovation and the remainder of the existing house has 3/4" over 1/2" giving 1 1/4" (actually less due to a couple refinishings).  New kitchen would be 3/4" over 3/4", thus a small 1/4"+ threshold.
    2. karp | Feb 26, 2007 08:55pm | #7
      ditto
  2. bruce22 | Feb 28, 2007 03:10am | #12
    I have to agree with the 3/4 subfloor. If you're goin down to the joists, why not go better instead of just o.k. For the extra expense and effort you get a stiffer floor, less likely to squeek, blah, blah, blah. Also more likely to even out ups and downs in the f.js.
  3. semar | Feb 28, 2007 03:22am | #13
    My suggestion is like some on the forum: go down to the joists, rescrew 3/4" T&G sheathing on it. This way you will know for sure you have a solid subfloor.
    My other suggestion is not to use hardwood floor in a kitchen. It is a fad at the moment. Over the 35 years I have been in construction; almost all my customers ripped the hardwood floor off after some time and re-installed other materials like linoleum or cork or tile.
      Woody78 | Feb 28, 2007 03:00pm | #18
      My 85 year old house, which was the cookie cutter development design of its neighborhood 85 years ago, has a maple floor. So do at least a half dozen of my neighbors. We like it and want to match it as we just added on but it is narrower than todays norm of 2 1/2" and matching the color on something with this much age and who knows how many recoats is tough.
      1. woodroe | Mar 01, 2007 02:58am | #22
        Hardwood flooring is readily available in 1-1/2" and 2-1/4" widths; they are the most common widths used. In fact they are the most common widths. An experienced flooring guy should be able to put a slight stain on the new floor to give it the aged color of the older wood floors.
Solar Shingles in Austin
A Tesla roof powers this five-bedroom Texas home and then transfers extra energy to the power grid.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
