I’ve recently removed the particle board
section in my kitchen because it had got
damaged from water. I’ve replaced the
particle board but it does not look like
the existing particle board. The existing particle board has a dark brown finish on it as if it was coated with something. Should I be coating the new piece of particle board with the same stuff and can you tell me what it is? Thanks, Dave
I've recently removed the particle board
damaged from water. I've replaced the
