I recently completed a granite tile countertop project and I now have a problem trying to install a new drop in kitchen sink into the countertop.
The total thickness of the countertop build up is almost 2″ ( 2 layers of 5/8″ plywood with adhesive between the sheets / thinset / ditra underlayment / thinset / 3/8″ granite tile). The bolts that are supplied with the sink are not long enough for the supplied clamps to secure to the underside of the plywood.
Does anyone know where I can find longer bolts or extension for the supplied bolts? I am also open to any other solutions to this problem.
Thanks;
Paul
You are probably going to have the same problem with your taps too. Use a Forsner bit to take down the thickness of the plywood from the underside where the clamps and taps go. Hope there are no screws nearby...
(edit: for spelling)
Edited 4/12/2009 11:40 pm ET by fingersandtoes
router to remove material as needed.
Elkay has longer clamp lengths available for their sinks. Don't know about others.
