I’m puting together a resources section on my website and I need a colection of online calculators to link to. Anyone know of any especially good ones?
Cheap Tools at MyToolbox.net
See some of my work at AWorkOfWood.com
Try this:
http://www.csgnetwork.com/converters.html
http://www.bobistheoilguy.com/conversion.html
http://www.refdesk.com/
http://www.awc.org/calculators/span/calc/timbercalcstyle.asp
http://www.southwire.com/voltagedropcalculator.jsp
They should get you going.
Bob
http://www.awc.org/calculators/span/calc/timbercalcstyle.aspI LIKE that one - more options built into it.
http://www.josephfusco.org/Calculators/Box_cutter.html.
Hey Bill, that looks like a really handy calculator. But just wondering if you know Joseph Fusco. Not sure what everyone else is seeing but for me his site is kinda screwed up, with left, middle and right colums sort of overlapping.--------------------------------------------------------
Cheap Tools at MyToolbox.netSee some of my work at AWorkOfWood.com
No, I don't know him.He used to be a regular and does pop in from time to time. Many someone that knows him will relay this.Here are a couple of others.http://forums.taunton.com/tp-breaktime/messages?msg=104223.46.
"He used to be a regular and does pop in from time to time."
I was pretty sure I knew the name from around here, why I figured you might know him. Thanks for the link. :)
Edited 5/8/2008 8:40 am by Ted W.
EDUCYPEDIA ONLINE CALCULATORS
MARTINDALE'S CALCULATORS ON-LINE CENTER
McFeely's has a couple-one that might be handy-Deck Calculator.
http://www.quittintime.com/
Thanks for the replies. I'm going to work on my "Links" section over the weekend. Of course the more the merrier, so keep 'em coming in. --------------------------------------------------------
A few morehttp://ca.geocities.com/web_sketches/calculators/http://www.mathematische-basteleien.de/spiral.htm(the second location has a lot more than spirals, but some are not in English)
http://www.mcfeelys.com/tech
Here's the link.
Thanks for all the replies, everyone. There's a bit of a hold up on making my resources directory, the free software I was trying to use turns out is worth every penny. I bought something way better to use for the directory but now I have to get it set up.
BTW, I plan on a lot more than just calculators, but it seems a good place to start. Anywayz, thats the update. Any more calculator links are welcome. More specifically I need construction related calculators, such as materials estimating, load capacity and spans, measuring areas, etc... There's a lot of good suggestions already but there can't be too many. --------------------------------------------------------
http://www.wendrickstruss.com/pages/areacalc.htm
http://www.wendrickstruss.com/calculator/index.asp
http://www.twperry.com/spancalc/index.html
is what I use most often
I don't but I have a request.
When you get the list all compiled can you post a link to the entire list ?
I sure appreciate you doing all this work for the entire BT family!!
I most certainly will. However, calculators is only for testing while I get it set up. The objective is to create an all around resource directory including building products, services, info and whatever else I can think of. I'll be asking for input on that as well, once I get it set up. --------------------------------------------------------
You got some good ones there.
This is one that I use quite often.
http://www.1728.com/circsect.htm
“The world is a dangerous place, not because of those who do evil, but because of those who look on and do nothing.” —Albert Einstein
Ted
I don't know if these will be of any use to you, but here are a few links.
Concrete Calculator, Span Calculator, Crown Moulding Calculator, Box Cutter Calculator, Timber Frame Calculator, Construction Calculators 1, Construction Calculators 2, Woodworking Calculators 1, Woodworking Calculators 2, Geometry/Trig Calculators, Building Science Calculator, Estimating Calculator, Accounting Calculator, Miscellaneous Calculators
Rich
Thanks Rich,
Some of them have already been mentioned but they're all good suggestions. I'll be putting together all of them from this thread as soon as I have the directory set up. Had it going at one point but wasn't working too well, so am redoing the whole thing.--------------------------------------------------------
