LALLY COLUMN
| Posted in General Discussion on January 13, 2000 05:59am
iAM INSTALLING A LALLY COLUMN IN THE BASEMENT TO SUPPORT A HEADER ABOVE.DOES SOMEONE KNOW OF THE BEST WAY TO INSTALL ON THE CONCRETE FOOTING,ONE IDEA I HAVE IS TO BOLT THE LALLY COLUMN TO THE EXISTING HEADER ABOVE AND SUSPEND IT OVER THE HOLE WHERE I CAN FILL IT WITH CONCRETE UP TO THE BOTTOM PLATE OF THE HEADER AND THEN BOLT IT IN.THE OTHER WAS TO SHIM THE LALLY COLUMN AFTER THE FOOTING HAS SET UP.ANY OTHER IDEAS WILL BE APPRECIAITED…RAY.
  1. Guest_ | Jan 12, 2000 11:05pm | #1
    Ray, doesn't your column have a screw jack to fine tune it?
  2. ray_toro | Jan 13, 2000 12:53am | #2
    Calvin,the structural engineer gave me the drawings for a 4" column.He did not specify if I can use an adjustable type,it just points to a standard column..
  3. ray_toro | Jan 13, 2000 05:59am | #3
    iAM INSTALLING A LALLY COLUMN IN THE BASEMENT TO SUPPORT A HEADER ABOVE.DOES SOMEONE KNOW OF THE BEST WAY TO INSTALL ON THE CONCRETE FOOTING,ONE IDEA I HAVE IS TO BOLT THE LALLY COLUMN TO THE EXISTING HEADER ABOVE AND SUSPEND IT OVER THE HOLE WHERE I CAN FILL IT WITH CONCRETE UP TO THE BOTTOM PLATE OF THE HEADER AND THEN BOLT IT IN.THE OTHER WAS TO SHIM THE LALLY COLUMN AFTER THE FOOTING HAS SET UP.ANY OTHER IDEAS WILL BE APPRECIAITED...RAY.
  4. Guest_ | Jan 13, 2000 05:59am | #4
    Ray, it wouldn't be one of those junk telescope it out and put the pins in columns. It is prob,(but find out) the HUD approved 4" steel suitable for beam support columns. If it is, you will be asked at order for the size. They come in I believe 3" increments. ex: 6' 3" to 6' 6". They will have a turn screw that will take them up or down to make up that 3" variable. Check with the eng. but I'm thinking these are the ones.
Pressure Washing Made Portable
This electric pressure washer is compact, lightweight, and easy to maneuver.
  • Tall Deck on a Sloped Lot
  • Making and Installing Wood Wall Paneling
  • Hand-Sanding Hack
