Laminate over laminate?
Longstreet | Posted in Construction Techniques on April 6, 2005 08:25am
I have built a few countertops from scratch, but I have a possible job re-surfacing.  The base is sound, so it seems silly to redo the whole thing.   Can the new laminate be glued over the old, and if so, how should I prep the surface (old laminate) for the adhesive?
“You couldn’t pay me to run into a burning house.  I’m a VOLUNTEER!
  1. csnow | Apr 06, 2005 09:18pm | #1
    Did this once.  Worked great.  Used a chemical deglosser, then sanded it to add some extra 'tooth'.  In retrospect, the deglosser was probably redundant with the sanding, though it did degloss.  Nasty fumes from that stuff.
    Pay special attention to prepping the edges.
  2. Mitremike | Apr 07, 2005 10:08am | #2
    Yes you can --this topic has been covered many times so a search will give you good results.
    sand with 50 grit to break the old surface-you don't have to go thru to the substrate ( the brown kraft layer) just score it
    Clean well
    glue well --use stickers like blind slats or dowels
    roll from center--don't miss any areas
    let set up and then do your cut outs and enjoy
    Mike
    " I reject your reality and substitute my own"
    Adam Savage---Mythbusters
    1. Longstreet | Apr 07, 2005 10:16am | #3
      Thanks guys."You couldn't pay me to run into a burning house.  I'm a VOLUNTEER!
