A few years ago I glued laminated oak flooring onto a well-cured concrete slab. In a few spots the flooring has separated from the glue, creating a hollow sound when walked on with heels or hard shoes. Obviously, I didn’t use enough glue, or I didn’t weight the floor properly when I installed it. Does anyone have any suggestions on fixing the floor, other than cutting out the offending planks and re-installing. The floor is 5″ wide strips, random lengths.
Thanks,
Jack
I suspect the real problem is that you didn't install a foam underlay. Unforunately there is no easy fix for that. Take it all out, put down poly, foam, and then the floor.
Scott.
How do you glue floorboards down to a foam sheet?
Damn, you beat me to it!
You use foam board adhesive, none of the solvent stuff cus it'll melt the foam.
I like Wayne's idea better, Don't wear shoes in the house.
I was thinking along the idea of drilling holes, perhaps at the corner of where the boards butt together. If done in this manner, I would need a glue that has a high viscosity and would adhere to both the floor and the glue that is underneath. Any suggestions?
Thanks,
Jack
I should add that the glue I used was the one recommended by the flooring company, Bruce Hardwood Flooring.
Jack
I would go with a glue that has low viscosity so your injection hole can be smaller and the flow under the flooring would be easier. I am thinking along the line of urethane or epoxy and weigh it down while it sets.
Have you talked to the place where you bought the flooring from?
Sorry guys, I think I jumped the gun. When I see 'laminated' anymore, I automatically think of 'laminate', the el-cheapo paper/plastic product that you put poly and foam underneath and click together. Please strike my response from the record. ;)
Scott.
No way. We're gonna archive that comment and use it against you for the rest of you wife. I mean life.
Hahahahahahahaha.....
Ok, but I'll be watchin' you too. When you least expect it.....
EXPECT IT!!
Cheers,
Scott.
Edited 11/13/2005 2:20 am ET by Scott
Edited 11/13/2005 2:21 am ET by Scott
Thanks, everyone, these comments:
"I set the tubes of pl400 in a HOT water bath to ensure they would be viscous. Then pop a hole in the floor and vac away all the sawdust. Then snip the tip and PUSH VERY HARD to be sure it doesn't ooze back. Set a weight on it and it should be fine. You don't need to have complete coverage! Too litle is better than too much!"
And the suggestion regarding using a polyurethane glue are what I was looking for. I'll give it a try over Thanksgiving weekend.
Jack
I've seen people drill small holes in the floor and inject glue under the flooring. Then just fill them with a matching putty.
Headstong, I'll take on anyone!
I've had to do this on a couple of repairs, and it depends on how much you are willing to see the holes ( alot of little one or fewer bigger ones)
The other was a floating floor, which then WOULD have a foam underlayment, and you CAN'T glue down, but the HO did not level the floor first, and it had a big dip. I carefully masked off the hole and used minimal expanding foam to help fill the dip. Again too little is better! Watch out for back pressure! (don't ask)
