My old Sharpe finish spray gun recently passed away. I do cabinetry for personal use, slightly more than occasional. The local paint store carried only high priced airless guns, or airguns w/ expensive setups. I just want to spray Valspar Laquer so I bought a cheap Sharpe FX200. I went to spray my new maple and purple heart desk for my daughter and quickly became frustrated. No matter what pressure I used, I couldn’t get enough volume for the laquer to “flow”, resulting in dimpled and scattered finish. On a small piece (drawer front) I could get enough laquer to make it flow, but on the the larger pieces, no luck. I also got laquer buildup on the nozzle and some dripping. I played w/ the pattern adjust and of course the volume – no luck. Can someone recommend a better gun? My Hitachi 4 gal. compressor has worked in the past, so I don’t think that’s the culprit. Thanks, Dave
In this episode, listeners discuss outdoor lighting, air-barrier improvements, DIY insulation, and more.
I use a accuspray lvlp. I spray it with a 4 gal 1 1/2 hp emglo. Compressor runs alot but the gun never has to catch up.
http://www.compliantspraysystems.com
Jeff Jewett also sell some set ups that would work as well
http://www.homesteadfinishing.com
hope this helps
Caution: This message may contain "For Official Use Only" (FOUO) or other "sensitive information" is not intended for non-official disclosure. Do not disseminate this message, except to persons who require it for official Breaktime purposes, without the approval of the individual originating this message or other authorized official of the Taunton University. If you received this message in error, please delete it.
