Laser Levels in flooring layout
| Posted in General Discussion on January 23, 2000 03:48am
Anyone with information about using laser levels in flooring layout, including what brand, what you like about the unit, what you don’t like about it and how much you paid.
I am doing a hard wood floor installation in a house that is as crooked as a newly admitted lawyer and I have to run a straight shot over 38′ in length. Complicating the whole matter is a layout that requires a decorative picture frame of contrasting cherry, brass and walnut that surrounds all of the predominant features in the three rooms. While it is easy enough to snap a line for the intitial averaged layout point, when I turn a 90 degree to establish the intersecting segment of the picture frams all hell beaks loose.
I suppose I should have thought of this a long time ago but averaging layout lines can usually render an adequate layout relative to baseboard gaps and the like.
My inclination is to go with something like a ProLaser PL5 but I want to be sure that this isn’t overkill for this application or others that I might encounter.
  1. Guest_ | Jan 22, 2000 09:04am | #1
    Tom
    What about a low-tech, inexpensive option like trammel points and geometric construction???
    Scott
  2. thomaswalsh | Jan 22, 2000 08:34pm | #2
    Scott:
    Been there and done that, I am working by myself and the layout is hideous. Was looking for a way to speed the process. The walls shouldn't be this far out of wack but they are and I am not about to go through the process of correcting someone else's error at this point.
    If I'm missing something in the analysis please advise.
    Tom
  3. thomaswalsh | Jan 23, 2000 03:48am | #3
    Anyone with information about using laser levels in flooring layout, including what brand, what you like about the unit, what you don't like about it and how much you paid.
    I am doing a hard wood floor installation in a house that is as crooked as a newly admitted lawyer and I have to run a straight shot over 38' in length. Complicating the whole matter is a layout that requires a decorative picture frame of contrasting cherry, brass and walnut that surrounds all of the predominant features in the three rooms. While it is easy enough to snap a line for the intitial averaged layout point, when I turn a 90 degree to establish the intersecting segment of the picture frams all hell beaks loose.
    My inclination is to go with something like a ProLaser PL5 but I want to be sure that this isn't overkill for this application or others that I might encounter.
  4. Guest_ | Jan 23, 2000 03:48am | #4
    Thomas:
    No way easy here! I'm currently involved in a prefinished rather easy layout of borders. I'm seeing angles of 32º which should be 30º and dry laying cuts that are 15½º and a tad more. It isn't any easy task and I don't think any easy solution is there. It happens. If you have three different rooms from what I see, it's easy to cheat and line things up accordingly as you enter the rooms on the installation. You'd be surprised how much you can "turn" the direction just a shade to line it up.
    Forget the laser..use chalk lines and adjust..Any help?
