Latex Primer over Cedar Trim
newbuilder | Posted in Construction Techniques on April 7, 2007 12:43pm
I’m trimming out some vinyl windows and will be using cedar 5/4.   I won’t be getting to the painting of the trim for a few months and want to have it sit protected for the duration so I want to prime it with a good exterior primer.   Someone at HD told me ONLY to use an oil-based primer with cedar!   I don’t want to work with oil base which then must be followed with oil based over coat /final coat.
Is it or is it not OK to use a good quality latex primer over cedar?
Thanks –
T
  1. Kgmz | Apr 07, 2007 12:54am | #1
    They are correct about using a oil based primer over cedar. You will get too much bleed through with a latex primer.
    You can use latex paint over a oil based primer.
    Why are you using cedar if it is going to be painted. Up here in the NW most everyone uses WhiteWood, this is a pre-primed trim wood available in all trim sizes for window trim, corner boards, facia, barge, etc.
    1. newbuilder | Apr 07, 2007 04:11am | #5
      Thanks to all who responded for all of the feedback.
      Kgmz >>> this "Whitewood" ... where is it 'gettable' ... Home D???
      I wanted to use something that would have great longevity and that I wouldn't have to mess with much after installing.  I can't find anything about 'whitewood' online other than related to furniture ... why do you speak of it as such a 'prized' material for trim?
      Thanks -
      T.
      1. dockelly | Apr 07, 2007 04:47am | #6
        http://www.azek.com/this was used on my house.
      2. alanj | Apr 07, 2007 06:15am | #7
        I use pre-primed facia and barge boards, generally to save time. Most good lumberyards carry 1" and 2" material around here, in various widths. The quality of finish is mediocre-obviously machine sprayed with blobs and skips. These may cause problems later.I use latex (actually acrylic) primers over cedar on small jobs and when budget can afford it.I am in a similar climate to yours. I am in Vancouver, BC. Make sure you use a premium brand--Kilz or Zinnser--My thinking is that a water-based primer is better on top of wet lumber.I can send you pics of trim that I painted and installed 2 1/2 years ago that look like new. Thay have NO topcoat.Painting all six sides is important and not that time-consuming as these primers dry very quickly.Good luckAlan
      3. Kgmz | Apr 07, 2007 11:31am | #8
        I have actually seen some whitewood at some HD's. But the best place to get it is a real lumber yard, they will have all sizes and lengths. From 1x2 to 1x12, 5/4x3 to 5/4x10, and 2 x stock.
        I like it because it is primed all the way around and saves time. And it is true some pieces can be ugly, but when I go to the lumber yard and pick it up I am choosy and pick through the stack. If it is delivered I take the ugly pieces back and get better ones.
        We have accounts at Lumbermen's and Gray Lumber, so that is where I usually get it.
        Here is one brands brochure.
        http://www.woodtone.com/docs/RealTrim%20Web%20Brochure.pdf
        These guys are manufacturers based in Seattle and Vancouver, BC.
        And when you read the brochure it will say it is made of SPF. SPF stands for Spruce-Pine-Fir. Just in case you don't know. Also it mentions texture planing, these boards are not smooth on one side. It has a texture planed on it which gives it a better look and helps hold the paint.
    Mongo | Apr 07, 2007 02:16am | #2
    I'd do what was previously recommended...oil primer, latex top coat.
    Mongo
  3. BoJangles | Apr 07, 2007 02:22am | #3
    Somebody at HD actually gave you the right advice!
  4. Geoffrey | Apr 07, 2007 02:46am | #4
    the answer to the question is, no it's not all right to use a latex primer over cedar.
    primer won't really "protect" the wood, it just gives a "tooth" for the finish coat to adhere to and helps seal the tannins from bleeding through. If you let the primer sit for " a few months" it will have lost all those properties you're looking for it to provide..and basically will have been a waste of time and money..... as stated, you can use latex over oil-based primer.
                                                           Geoff
