I have a house built in 1921. It has a standing seam metal roof over the large front porch. The roof is designed such that water runs to a small channel at the roof edge. This channel leads to down spouts located at each corner of the porch. In wet conditions, I get water dripping from the soffits underneath the channel in certain locations where water tends to pool. Several years ago, I had a respectable contractor install a rubber membrane in the channel. That solved the problem, until I replaced the soffits (which were rotten from all the leaking water).
Now, water must be seeping under the membrane. Any product or process I can use to reseal it? What is the best solution for fixing the problem (aside from replacing the roof).
Rob - 1921 is likely to be a terne metal roof. One of the problems, particularly on porches, is that they rust from the
i underside
and don't look as bad on the top as they really are. I'd really be inclined to recommend that you consider replacing this roof with standing seam lead-coated copper, standing seam copper or Follansbee Terne II. You'll probably get some posts about ditching the internal gutter but in a whole-roof rehab, if done by a competent roofer, this shouldn't be necessary. If you use Terne II you can use TCS (Terne Coated Stainless) gutter lining, which will be around long after you and I are dead. These materials are solderable and repairable. (PS - Hope you backprimed your soffit materials). Yes, this is an expensive approach, around here copper is running about $1,500/SQ (100 SF).
If you just can't see replacing it, you can click here for a case study on AcryMax, an acrylic roof coating. I've spoken with the owners and after a year this coating is still going strong.
PS - You didn't say whether or not this roof had a
i color.
Many terne roofs were painted red, green or gray. If maintaining a color is important, the AcryMax coating system or new Terne II may be the way to go since painting (and maintaining paint) on lead-coated copper or copper is somewhat difficult, while Terne II
i must
be kept painted, and there are several colors available in their RapidDri product line.
