Ledger board and joists in a barn ?
| Posted in Construction Techniques on August 20, 2004 06:10am
What sort of fastening should I use to attach a ledger board to the inside wall of a post and beam barn building (130 year old barn) to support floor joists for the second floor? The 25 foot long ledger board (a 2×10) will have 17 joists attached to it (2x10s, 16″oc) with joist hangers. The barn wall has exposed, uneven, roughly 4×5 studs and three 8×8 main posts. The current plan is to use framing nails and 5/8 x 5″ lag screws to attach the ledger board to these posts and studs (attaching to the uneven studs will require some spacers). The joists span a 12′ simple span which will support a typical plywood and hardwood floor (this will be occassional-use living-type space). Does this sound like the right idea?
You can email me with thoughts at [email protected], but remove the YYY first.
  -Kevin Ware
    Sphere | Aug 20, 2004 06:21pm | #1
    belt and suspendes approach, would be let the 2x10 INTO the post, or atleast another 2x vertically scabbed to the post..
    but your plan sounds pretty rugged.
    BossHog | Aug 20, 2004 09:34pm | #2
    I don't see how you could you get enough nails and lag bolts into a ledger board to be able to support the weight you'd need to support.
    Sounds like you've got roughly a 12' by 20' area. At 55 PSF, that's a 13,200# design load.
    Obviously, only half that will go to the side where the ledger is - roughly 6,600#. Spread that over something like 5 (?) posts and you have to connect for roughly 1,320# per post.
    A single ledger board probably won't even cover that.
    I refuse to be intimidated by reality anymore. What is reality? Nothing but a collective hunch. [Lily Tomlin]
Two Ways to Test Windows
  • The New Old Colonial
