I am about to build a 14″ high platform 13′ x 54′ for a church. I’m running 2×8’s accross the 13′ from on top of a six inch wall to a ledger. The ledger is to be attached to the existing walls which are steel studs covered in drywall. How should I attach the ledger to the wall? What fastener and how many per stud. The lumber yard suggested drywall screws….
Thanks.
Rich Beckman
Rich,
Joseph Fusco
"The price of apathy towards public affairs is to be ruled by evil men." -- Plato
*I would strongly advise against using drywall screws for structural building. Use nails.
*Rich: Good advice in both posts. Drywall screws are not structural screws. Structural screws are available any a good supply house in our area. If you plan to put much weight on this platform do not rely on any screws into the steel studs unless they are a structural stud. Even then I would get an engineer to ok it. Too much liablility.Ron.
*reinhard & Ron,I apologise. I was too subtle. I know the drywall screws would not be the way to go. When I questioned the shear strength of the drywall screws, the lumberyard guy said that if you use enough of them, the strength would be sufficient. That's why I asked here.JoeThanks. I am building the knee wall and I will be putting a support halfway also. The knee wall was my first thought, but I somehow talked myself out of it (and the guy at the lumberyard went right along).Rich Beckman
