Lentels and window flashing
Leland | Posted in Construction Techniques on March 20, 2004 07:27am
I’m looking for information on how to install windows with a nail fin (such as Marvin) in a 12” exterior wall with a 4x cedar lentel.The windows are 4 9/16 jambs and I would like to set them appx. in center of the wall.stucco ext. I see a real flashing challange.
  1. DanH | Mar 20, 2004 02:04pm | #1
    Cut off the fins and install them conventionally?
  2. Piffin | Mar 20, 2004 03:04pm | #2
    Don't buy thm with fins for an atypical installation.
    There is a world of information missing here for specific advice.
    Framing materials? Masonry wall?
    Stucco thickness and type?
    Lintle exposed to weather?
    Interior stucco?
    Size and type of window?
  3. mdresimprov | Mar 20, 2004 04:43pm | #3
    I agree with discarding the fins and place that window in the hole wherever you want it. If you really, really are insistant on using the fins and the framing is not done, then you can oversize the opening 3 inches all around and install a 4 1/2 (2X6 ripped) buck in which you can attach the nailing fin. The exterior elevation will now have a 1 1/2+ on each side that will need to be filled or built up with foam to join the existing stucco.
    MES
Choosing a Paintbrush
  • The New Old Colonial
