level floor on slab?
rusty52 | Posted in General Discussion on July 24, 2012 09:01am
Hello,
I have a slab on grade floor that is way out of level.  It’s an old house and we plan on a bigger remodel in the next 5 yrs or so, so pulling out/ fixing the slab isn’t gonna happen right now.  We are in Northern CA, so it never gets too cold.
I plan on the xps over slab with 2 layers of 1/2 inch ply or maybe on 3/4 layer for an engineered floor or laminate on top.
https://www.finehomebuilding.com/how-to/qa/finishing-a-basement-floor.aspx
Question is, I need to level the 9 x 12 ft room as much as 3-4″ corner to corner.  So, XPS and them lay sleepers on top? or frame it like a deck and put the XPS in between the sleepers?  The floor is dry, plastic taped over the floor results in no moisture.  I was going to go without a vapor barrier so the floor can breath.
thoughts on best approach.  self leveling cement is out of the equation too.
thanks
-Russell
    xxPaulCPxx | Jul 25, 2012 02:00pm | #1
    Well, it certainly sounds like you are on the right track so far.
    Why no SLC?
Picture-Perfect Pergola
