In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
little help w/ router?
Sphere | Posted in Tools for Home Building on August 31, 2004 03:29am
OK, I should know this..BUT..my PC 1729 router is really acting up..soft start is cool, give it a load, it bogs…I have the speed dial at amidships, running a fairly large, 3/4 RAD round over, in a table.
Apply load, it shuts off, ( I taped the kill switch, no help), the dial speed control was kinda sticky, I worked it back and forth, and she comes up to speed, but no guts…
On a dedicted 20amp, 20′ from the breaker..12/2 w/g
I am inclined to think the eletronic moter control ( for soft start/laod) might be shot..any thoughts?
It was living in a bad place for awhile, damp, nasty, dark..but really only has about a hundred or less hours on it..(of three yrs)
Do I really need to use my old Royobi 600 to finish this stuff?  It has been a worker bee forever..the “new” PC was to be the replacement…
basically, I am flummoxed..what gives?
  1. alias | Aug 31, 2004 04:08am | #1
    sphere- how hot do the plugs get?? i have taken my routers apart if sat for a while and blown and scrubbed clean with a brass brush especially around the brushes and wire coils. but your case sounds, like your gut assesment is right. those the after market speed dial controls are a crap shooti've fried those things after milling window muntins and after 35-45 hrs they got real lazy the one i had it was a rsco1 with the replaceable fuse. i was replacing the fuse on one everyday and on another everyother day. the third it hit the trash.... f..i..n..i..t..o. go with a very thorough cleaning all the wire connections with a brass brush or a dental tool alone and air or a piece of adhesive fine grit 220 or higher attached to the dental tool, check the replacable fuses (if that the one you have), the plugs. then worst case hit the tool service for a 50$ assesment they'll usually apply to the cost i,ve had portercable routers with out the after market dumoflicky attachments that have lasted for 18-20 years with maybe 1-2 tops service in that time.... oh yeah happy birthday my bro share's your day.......bear
    "expectations are premeditated resentments"
      Sphere | Aug 31, 2004 04:29am | #2
      Bear, I din't think to feel the plug..but ya know it's sounds like what ya said..
      I'll try again to run somethin, and see if the plug gets hot..
      I am not willing to send it away, or tear it apart...I need it now.
      Damn, I did do a ton of table work w/ big bits ( sash cope and stick) but geeeze, it's only like 100 hrs. or so....
      I think the eles. are FU'd..voltage drop? I MAy have used a long cord in the past..
      Thanks, I blew it out w/ air...no change..
      Hey, I don't talk Bday, 44 is too old fer that..
      1. alias | Aug 31, 2004 04:54am | #3
        good luck ...porter cable makes a good router and they take a beatin' those long bits need a big router the 7538 is what you need for those bits. i cant emphasize that enough there pricey but well worth it. that one got soft start , plunge, anda 10,000- 21,000 rpm built in switch. it's got lottsa 'nads' and heavy so if you have to use it up right it has surprising control but would keep it the router table. the thing weigh's as much as a bowling ball. careful again with those big bits in the under sized router they can be a problem when bogged down and the weak link is the router bit/ collet connection. and.....well ...you know can happen..... so be careful..huh... slainte' bear"expectations are premeditated resentments"
DeWalt Recalls 12-in. Sliding Compound Miter Saws
Purchasers of certain models should stop using the saw immediately and contact DeWalt to receive a free repair kit.
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Installing Prehung Exterior Doors
  • Podcast 485: Air-Sealing a Mobile Home, Owner/Builder Tests, and Ready-to-Tile Shower Bases
  • Podcast 485: Members-only Aftershow
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
