I’m going to install a wood I-Beam to reinforce a garage ceiling. I would like to install Lolly Columns at each end. What is the preferable way to cut lolly columns to size. I have seen several different methods. What is the easiest way?
Joel
Joel
Easiest way would probably be a giant cutoff saw.
In the absence of that, you can use an angle grinder with a cutting wheel.
Mark the circumfrence square by wrapping a piece of paper around it.
Cut around the metal on the line, then use a chisel to snap the concrete.
If any concrete protrudes, you can grind or chisel it off.
I've always used a pipe cutter.
"I've always used a pipe cutter."
Do you worry about damaging the cutting wheels when they hit the concrete?
No, they last a looooooooooooooooong time. Those big pipe cutters are for building muscle, and a dull wheel just makes for more muscle.
But some Sumbitch stole mine, so no more workouts for Joe.
Joe H
Not to say I won't but never have had a problem. Don't know about other brands but the big Rigid pipe cutters are pretty rugged and the replacement wheels are relatively inexpensive if you do have to replace a cutting wheel.
