lolly columns in middle floating floor
handygman | Posted in General Discussion on November 7, 2005 03:47am
Hi,
 This is about floating floors. How do you handle lolly columns. I haven’t seen any edge strips that handles curves.
Thanks in advance.
  1. piko | Nov 07, 2005 04:05am | #1
    Let's see: use vinyl baseboard to wrap around; make a square plinth around the column; cut a section out of the flooring, cut a hole the req'd dia and halve that to lay flat on the floor - then bring the flooring up to it and cover the necessary gap with transition strip; wrap the whole column with w.h.y. to make it a 'real' post; or perhaps get someone to mill you something where your imagination will work.
    All the best...
    To those who know - this may be obvious. To those who don't - I hope I've helped.
    1. handygman | Nov 07, 2005 04:09am | #2
      great idea. thanks for the advice.
