I am a renovator in Brooklyn NY. I often save beautiful old bathroom sinks that are bound for the dump. I would like to have them re-baked to renew their porcelain to newish state. After doing some research it seems that there are many reglazers(they acid etch then spray a white poly urethane), but that seems like a very short term solution. Does anybody have any contacts, sources, or suggestions.
Structural steel and strong connections help a raised floor resist high winds and water.
Greetings d, As a first time poster Welcome to Breaktime.
That subject has been addressed here on Breaktime a number of different times in the past.
In the event you fail to receive the information you desire, you might find it in the archives.
If you scroll down in the lower left corner of your screen there is a search function that will take you to previous threads dealing with whatever you type in the search bar.
If you type in 'porcelain' or other keywords of the subject matter you'll get a supply of data from those old threads.
Cheers
'Nemo me impune lacesset'
