Looking for vacuum attachment for drills
Anybody ever seen a vacuum attachment for hammer drills? Got to drill hundreds of holes in a concrete ceiling and would like to avoid having it rain down on me.
An FHB Podcast listener wonders if they can fix a failing foundation with PWF, the crew weighs in.
Hilti makes an onboard "vac" box that uses the exhaust of the drill motor I think to make it collect. There's a brush end on it that the bit slides through. It has a pull and clean box with a filter so what's sucked up-doesn't blow out.
Works on overhead and underfoot.......very well.
This is on their rotary hammer drills.
http://www.quittintime.com/
Bosch makes an attachment that fits some of their drills. Unlike the Hilti, it requires attachment to a vacuum cleaner. I don't have one, so cannot say how well it works.
Bill
Of course, you have to buy the drill.
How about-if you have three hands, you rig up a deep pan and put an outlet on it that your vac can hook to.
There used to be a "compass" cutter for drywall (can lites) that had the bit going through one of those plastic "lids" for a pie or cake. About 3'' deep and 8/9'' circumferance.
You could do the same only smaller.
I was just reading it this afternoon(Construction Equipment) Jan 08.
Haven't gone to the site but here's what you need -enviroboot.com
The one that looks the closest is EBCH-1 but I believe if we go to fernco site we might just have a TY that could do ya.
I went to the site but It's kinda luggi loading. http://www.enviroboot.com/products/EnviroBoot-EB-1.html
Edited 1/24/2008 8:49 pm by ClaysWorld
Somewhere, I saw somebody who took something like 1/2 a basketball, stuck the bit through it, pushed the rig to the ceiling and drilled away... probably too lo tech, huh?... besides, who would cut a b-ball in 1/2? Winterlude, Winterlude, my little daisy,
Winterlude by the telephone wire,
Winterlude, it's makin' me lazy,
Come on, sit by the logs in the fire.
The moonlight reflects from the window
Where the snowflakes, they cover the sand.
Come out tonight, ev'rything will be tight,
Winterlude, this dude thinks you're grand.
Yeah, bb in half.
or one of those faux kick balls for minimal dinero-probably of chinese origin-what the hey-first trip to walmart.
Man, on tv tonight...............more cleavage than the Star Diner.A Great Place for Information, Comraderie, and a Sucker Punch.
"I saw somebody who took something like 1/2 a basketball, stuck the bit through it, pushed the rig to the ceiling and drilled away."
I was kind of thinking the same thing - But maybe with a cheap playground ball.
If you had a mind to, you could cut a hole in the ball for a shop vac hose and duct tape it in there.
Kinda low tech, but I think it would work.
Nearly everyone will lie to you given the right circumstances. [Bill Clinton]
and then, there's something like this:http://www.karcher.com/int/Products/Private/Consumer_Indoor/Drill_dust_catcher/16791000.htmand, I think I've also seen something electricians use for cutting cans into sheetrocked ceilings...none of it sounds like a lot of fun to me <G>
use the MM's dust collector attachment and hold it on yur HD with a serious rubber band...
works great...
WOW!!! What a Ride!
drill the hole through the bottom of a plastic cup or margarine dish, will keep all the dust/grit from getting into the chuck and fan blades too!
Same idea only a little bigger - bottom half of a 1 gallon joint compound bucket.
Shop vac hose could be attached with one of those multi-sized hose adapter fittings - hose adapter could function as a handle.
Can usually do pretty well with a helper holding a shop vac rigid pipe next to bore hole. This assumes a helper is available.
Further assumes that everyone involved is willing to listen to the shop vac and the hammer drill for the duration - I'd be earplugging and muffing!
JimNever underestimate the value of a sharp pencil or good light.
How about this:
http://www.dustlesstechnologies.com/prodlist.php?cat=1
