my exterior door frame, the wood that meets the brick had gone south. Due to exposer to the weather. Do they make a replacement of the non particle type material, that might last longer.
Is it regular brick mold? I think that's available in plastic.
And if the stuff you have is particle board composite then regular wood would likely stand up to the weather better -- all of our wood brick mold is still in good shape after 33 years.
Azek.
http://www.azek.com/viewProduct.php?id=10
Mike Hennessy
Pittsburgh, PA
Here they sell PVC brick mold and other profiles at home centers and building supplies. When I order doors (from my building supply) I can specify PVC, or "jamb saver" I think it's called where they make the bottom foot or so out of a composite. Or, I can get just wood which I think are fine for well covered porches.
An important detail when installing doors with wood molding and/or jambs is to paint the bottom of the assembly before installing it. If it is to be installed in a masonry opening the edges need to be painted too before it is installed. Same for wooden framed windows.
For doors and windows installed in masonry openings, I like to caulk them in with either clear elasmeric (sp?) caulk or one of the other new - high performance clear caulks (not silicone).
I don't know of your specific install etc, but couldn't you just cap the whole works and be done with it?
Have a good day
CLiffy
Home Depot sells plastic brick mold and other wood replacement products. Also doors and jambs out of PVC or just the lower part of the jamb.
Yup
Buck Construction
Artistry In Carpentry
Pittsburgh Pa
I thot U woulda had that formed outta concrete and painted white!
Buck Construction
Pittsburgh Pa
