Mak Compressor Blues
Treetalk | Posted in Tools for Home Building on September 20, 2006 03:06am
My old Makita compressor started kicking the breaker trying to get up to running speed today.Its been running fine lately and its on a good line to the breaker box. Dont know where to start or what to check and at 60 lbs a lil hard to start sending off and where to send it off without doing at least some preliminary checks. Any ideas as to where to start.? The plug’s tangs do seem a lil loose in the outlet even if theyre spread. Guess could start with new plug end.?
    coonass | Sep 20, 2006 05:15am | #1
    treetalk,
    First thing I would check would be the unloader. Usually located on the check valve, it lets the pressure off the head.
    Let all air out then switch on.
    Plug into a different recpt.
    Replace cord.
    Sandpaper contacts on pressure switch.
    Rebuild motor.
    KK
  2. blue_eyed_devil | Sep 21, 2006 10:15am | #2
    A couple years ago we took two electric compressors (emglo's) into the shop for repair. They wouldn't kick on and they were popping the breakers.
    The tool repairman took one apart and found that sawdust had infiltrated the windings and brushes. He blew them clean with air and it ran fine. He then blew the electric motor clean on the next one without disassembling. It ran fine. He told us to blow the electric motor clean at least once a week.
    Let me know if that works.
    blue
    1. TOOS | Sep 21, 2006 11:43am | #3
      The examples that treetalk and blueeyeddevil give are specific issues from a more general problem.  That is, that something is preventing the motor from turning.  The motor then draws more current in order to generate more horsepower, and then the fuse, instead of the motor, blows.  The electrical system is functioning correctly.
      IOW, your problem may be mechanical, not electrical.  Take off any belts and rotate all the pulleys by hand.  The motor shaft should turn easily, and if the unloader is working right so should the compressor shaft.  But the compressor shaft won't turn by hand if you're trying to rotate it against compressed air in the cylinder.
      If the mechanical is ok, then go after the electrical.
    maddog3 | Sep 21, 2006 01:20pm | #4
    dial down the regulator to a low pressure.
    ..if it starts after the pressure drops,chances are pretty good the check valve has gone bad and / or the unloader is plugged up
    and the elec plug may be NG too
    .Wer ist jetzt der Idiot
Sloping a Deck: Is This Necessary?
Mike Guertin explains which areas of a deck you need to pay attention to in order to deal with drainage.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
