I’m re-doing my bathroom which was originally built in 1947 with a solid wetbed under ceramic tiles construction on the floor and all walls. Since the walls (which extend to the ceiling) and the floor are in perfect condition, can I tile over the existing tile with new marble squares? Would an epoxy thinset bond it to the tiles or would I have to use a 1/4 inch cement backerboard between the two surfaces? The reason I have to re-tile is that I need to replace a leaking lead line in one drain and so that section of tile has to come-up and new tile placed over the entire bathroom! I don’t want to rip out all the wetbed because it is in beautiful condition! Thanks!!!
I'm re-doing my bathroom which was originally built in 1947 with a solid wetbed under ceramic tiles construction on the floor and all walls. Since the walls (which extend to the ceiling) and the floor are in perfect condition, can I tile over the existing tile with new marble squares? Would an epoxy thinset bond it to the tiles or would I have to use a 1/4 inch cement backerboard between the two surfaces? The reason I have to re-tile is that I need to replace a leaking lead line in one drain and so that section of tile has to come-up and new tile placed over the entire bathroom! I don't want to rip out all the wetbed because it is in beautiful condition! Thanks!!!
