Marking Rebar
AdGustum | Posted in General Discussion on September 11, 2002 10:56am
I’ve been trying to find a way to visibly mark rebar for bending/cutting. For purposes of discussion, let’s say that I need better precision than a spray paint swath. So far, crayons have failed me.
TIA
  1. heck22 | Sep 11, 2002 11:04pm | #1
    http://forums.taunton.com/n/mb/message.asp?webtag=tp-breaktime&msg=23076.1
    Now just scale down.....
    Just kidding....:)  How about permanent markers,or a 3 corner file?
    jw
    what the heck
    was I thinking?
  2. Piffin | Sep 11, 2002 11:20pm | #2
    Soapstone marker - just like welders use.
  3. Egg | Sep 12, 2002 12:45am | #3
    Got another one for you.  Go to Office Max or similar store and pick up a correction pen.  Or white out in a pen dispenser, paints a line about 1/16" wide and clearly visible.  I have used it on hot roll steel, worked great.
    1. joeh | Sep 12, 2002 01:01am | #4
      Silver artists' pencils work well for marking out on hot rolled or rebar. I never had much luck with soapstone, it doesn't leave much of a mark.
      Joe H
  4. MarkH128 | Sep 12, 2002 01:42am | #5
    Chalk works ok.
  5. ReinTaul | Sep 12, 2002 04:29am | #6
    When you say crayons failed, were they lumber crayons? Those have worked well for me.
    1. bill_1010 | Sep 12, 2002 05:46am | #7
      lipstick, pick your color.
  6. 4Lorn1 | Sep 12, 2002 12:12pm | #8
    Recently I faced a situation where I needed a mark so the rebar could be moved to a cutting station and cut there. Lots of things kept me from getting a good measurement to call down. It was one of those odd place and mark situations. Nothing on hand worked until I tried a simple slip knot on a piece of masons line. Tied tight the slip knot doesn't slide and it can be done one handed. It seems no slower than digging for a keel and hoping you can find the mark later.
    Had I had any handy I might have used those plastic covered tie wraps. In a bright color the mason line catches the eye and is free, pick up what you need off the ground, on most job sites. A friend tried it but his would slip off. The trick is to go around the rebar and form the slip knot around the other end and then pull it tight. A timber hitch works well also.
  7. JohnSprung | Sep 12, 2002 08:14pm | #9
    How about white paper tape (like film editors used to use), then for really accurate marks, pencil on the tape.
    -- J.S.
    1. timkline | Sep 12, 2002 08:57pm | #10
      You will find what you need here:
      http://www.laco.com/cat/index.html
      Click on Valve Action Paint Markers
      We get them from our fastener suppliers. They work really, really well. carpenter in transition
  8. User avater
    jonblakemore | Sep 13, 2002 04:02am | #11
    Use a tie wire.   If you had a lot to mark (and I mean alot) you could buy a 100' reel of tie wire and one of those belt mounted dispensers and, with a pair of lineman's pliers, mark happily all day.
    Jon Blakemore
Picture-Perfect Pergola
