Are there screwdrivers out there that have a special tip or something to pravent damage to the head of the screw?
I was installing some drapery rods this weekend and the big screws that attached the brackets to the wall were powder coated black to match the rods. It was a shame that as I was screwing them in if the screwdriver slipped a little or even not at all it scraped off a little of the coating and revealed nice shiney silver beneath, which bothers me.
Made me wonder. What are you guys doing in these instances? Anyone have a tip or technique they could share?
you probably already did this, but make sure the screw and the screwdriver are well-matched. In other words, don't use a #2 Phillips bit on a #3 PH screw...
Otherwise, touchup paint. Model paints come in nice little jars so you don't have to haul around a pint or quart can everywhere...
You may even be able to get away with using a Magic Marker if it's up high and not likely to be noticed anyway...
I dont have a answer to the screwdriver problem, although I'd doubt that there is such a thing.
When I'm doing work with black or other dark colored screws I usually keep a magic-marker on hand and touch up with that, works great. Stain markers also work if the screws are bronzed. Find the color that matches.
You need a plastic or even rubber screwdriver. These are available at such stores as Toys-R-Us and others under the "Builder Bill" name or something similar.
~Peter
Less than 40 days left before the great Seattle-Tacoma earthquake. Another example of FEMA being clueless and doing absolutely nothing to prevent it.
lol wiseazz
Although I somehow knew I would get that joke. I guess I walked into that one.
Sure, I use a black permanent Sharpie on curtain rod screws when I can't get a black one to match. I can sort of see what I did, but nobody else will know how I customized the zinc screw.
D&L
Something else to consider is using an impact driver. They pulse the fastener in at a lower spin rate, making them easier to keep in control. I was surprised to find I could keep a flat head in a screw with an impact driver without camming out.
Also a CRX fanatic!
Buy paint markers to match color of screw heads. Black, white, yelloow.
Paint and presto shizam.
lots of screw driver types out there! check to see if the screws are pozidrive, philips will work but is not a true fit!
