Would like to know the best way to trim raised panel masonite doors (hollow core). Most of them only need a heavy eighth or so, some up to a quarter inch, but when I try to trim them with a skilsaw I can’t seem to get a clean cut even using a guide, the saw keeps wandering. Was thinking of buying a plainer, is this a good idea? If so which is a good one to get? Thanks all
Sharp blade in the saw?
you need a shooter board for your saw...
What's a shhoter board?
http://www.taunton.com/finehomebuilding/pages/hvt041.aspView ImageGo Jayhawks..............Next Year and daaa. Blues View Image
Search for the "shortening pre-hung doors" thread.
Jeff Buck has a nice method that works well.
Jon Blakemore
Mick, you trying to shorten them or narrow them? To width, plane. To length, circ saw and a shoot board or clamp a straight edge. If an even cut for length, you should be able to do it with a rip guide on that circ. saw. best of luck.
__________________________________________
http://www.quittintime.com/
Calvin, shortening them is no problem, getting the width is what isn't working out. Maybe a new blade will do it, but even using a guide clamped the saw seems to bind and doesn't flow smoothly keeps making irregular cuts, messed up two doors already. Glad there cheapies.
de plane boss,
de plane.__________________________________________
Electric plane even the Black and Decker model works great. Check your local Dewalt repair shop for replacement carbide blades at great prices. note bosch, makita, dewalt and B&d use the same blades.
Is the blade parallel to the sole of your saw? Perhaps checking that with a dial indicator will answer why the saw is binding.
Or perhaps your bearings are shot allowing the blade to assume an out of alignment posture.
Edited 4/22/2003 10:58:01 PM ET by GOLDHILLER
Shoe / plate on the saw tight? In alignment?
