Masons, acid washing?
frenchy | Posted in Construction Techniques on July 22, 2008 04:53am
I’ve been told that since I have a relatively large area of stone to acid wash and seal I can just go to a hardware store buy the acid and dilute it myself rather than buying the prediluted stuff.
 I’m reluctant to acid wash the stone because I bought special weather edged stone due to it’s wonderfully bright colors and I’m afraid it’s going to greatly dim some of that brillance.  However I left it exposed to the weather for a full year and there still is a great deal of film on the stone. Once wet it looks positively brillant and extremely colorful however it doesn’t rain all of the time.to see pictures of what I’m speaking about please go to 94941.7
Edited 7/22/2008 9:57 am ET by frenchy
  1. peteshlagor | Jul 22, 2008 05:45pm | #1
    It'll be fine.
    Use the concentrate (cheeper) and dilute yourself.  The shave monkeys to do this in the clinical lab business, so's it's within your level of expertise.
    Just remember, Acid goes into water, NEVER the other way around.
    Start with a 5% solution (1 part acid to 19 parts water).  Increase if insufficient.  Keep a garden hose close by in case it starts to react too much.  The water will stop the problem quickly.
    Then a nice sealer over the stone will be perfect.  Research your sealer well.  Some give a wet appearance, some don't.  Personally, the wet appearance looks better - depending upon the stone.
  2. dedubya | Jul 22, 2008 05:47pm | #2
    Welcome back Frenchy I was worried about you! If I were you I would try to find a product that is dedicated for stone washing , the stuff I use " Vanotrol 100 " has an acid base but also a strong detergent that works real well .
  3. frammer52 | Jul 22, 2008 06:32pm | #3
    Welcome back.  Come talk with us!
  4. drystone | Jul 23, 2008 02:09am | #4
    Depending on the type of rock, if it were acid treated and then sealed, there could be water trapped behind the sealer which would blister as the moisture tried to get out.  There is also the chance that the sealer would discolour with age.
    Wet stone looks good but be careful if you try to get that permanent wet look by, in effect, varnishing the stone.
    1. peteshlagor | Jul 23, 2008 02:18am | #5
      First, he needs to try his plan on a hidden or spare stone.
      But what would shellac do to the stone?
    hammer1 | Jul 23, 2008 03:50am | #6
    Folks around here haven't used muriatic acid for masonry wash in years. It's not environmentally friendly, hard on the landscaping and exposes the user to nasty fumes. The masonry washes these days are biodegradable, much less hazardous to the user and parts of the house. There are many brands available, here are just a few.
    http://www.dumondchemicals.com/html/safeneasy.htm
    1. frenchy | Jul 23, 2008 04:03am | #7
      hammer1
        Actually I need to change the PH of my soil slightly. (That area need a higher acid PH since I planted  a lot of Mugo Pines in it) To prevent damage to the grass I will turn on my sprinkler system and flood the area with water while I scrub the stones.. should only slightly increase acid level..
        hammer1 | Jul 23, 2008 07:39am | #9
        Your soil should be between PH 5.0 and PH 6.0. If you need to raise the present PH, that means it needs to be less acidic. In that case, add ground limestone. If the PH is too high, add sulphur. Washing you walls with muriatic acid isn't going to improve your soil PH.Beat it to fit / Paint it to match
      2. frammer52 | Jul 23, 2008 11:06pm | #10
        Too strong for walls frenchy, good to see you back.
        Can you join us in the tavern for a beer?
        Edited 7/23/2008 4:07 pm ET by frammer52
    boiler7904 | Jul 23, 2008 07:09am | #8
    I'd be concerned about using acid around the windows and wood trim. How does the window company want you to protect their product during masonry cleaning and will they honor a warranty claim if they can prove that you used acid for the cleaning?
    We always spec a detergent based cleaner for masonry. Prosoco is one brand that has a variety of products to meet your needs.
    http://www.prosoco.com/
    They also have some general information about cleaning and maintaining masonry.
    http://www.prosoco.com/helpfulliterature.asp
Behind the Scenes of a Concrete Batch Plant
The batch plant is your partner in getting high-quality concrete on your job site.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
