maximizing stairway width
| Posted in General Discussion on April 22, 2003 07:02am
I have a stairway that is 36″+ wide, and I am looking to install a handrail with minimum projection from the sidewall to provide maximum stairway width. Code calls for 36″ clear in the stairway, but if I can come within a couple of inches of that, and still provide a railing with adequate grip, and clearance from the wall for fingers I should be alright.
Does anyone know some tricks of the trade, or a vendor who would have brackets and or railing that would help solve this dilema. Thanks
  1. Davo304 | Apr 22, 2003 08:15am | #1
    Codes are pretty specific when it comes to handrails. Handrails must be no less than 1-1/4 inches in outside diameter AND the handrail MUST PROJECT out from the wall a minimum distance of 1-1/2 inches.  Typically, handrails project no more than 3-1/2 inches max. from the side wall.
    It would be best to consult with your code enforcement official as to how best incorporate a handrail into this stairway; since after all, it will be up to said official to approve or disaprove your work. I'd go with his/her  suggestion; that way you know the handrail will "fly."
    Davo
