MDF and Paint
Pnut | Posted in General Discussion on August 18, 2006 12:57pm
I have made some wainscotting using MDF and I’d like to paint them…Should I use a sealer first, then prime?
What would you suggest?
    IMERC | Aug 18, 2006 01:00am | #1
    is it preprimed...
    WOW!!! What a Ride!
  2. temujin | Aug 18, 2006 01:45am | #2
    I would use a primer/sealer like one of the products that Zinser sells. For any exposed ends, you can use spackling or drywall mud to get an even look. The ends are pretty porous so prime it really good or spackle it. Prime and paint it.
    1. Pnut | Aug 18, 2006 02:16am | #3
      Thanks for the replies people...
      No sides will be exposed...No it is not pre-primed...
      1. nikkiwood | Aug 18, 2006 03:02am | #4
        The only problem in painting MDF comes with the exposed edges. Since you have none, you can just prime and paint as you would any regular wood surface. I would suggest you sand the primer.********************************************************
        "It is what we learn after we think we know it all, that counts."
        John Wooden 1910-
  3. Jer | Aug 18, 2006 04:13am | #5
    What Nikki said.  Oil primer, because oil penetrates, then sand the primer and maybe even reprime.
    1. Pnut | Aug 18, 2006 04:21am | #6
      Thanks guys for the replies....I really appreciate it....
      1. nikkiwood | Aug 18, 2006 06:06am | #7
        I agree that an oil primer is best. BM has a great one called "Alkyd Enamel Underbody"; you can overcoat it with either alkyd or latex paint.********************************************************
        John Wooden 1910-
A New Approach to Foundations
