MDF in a Bathoom
MSA1 | Posted in General Discussion on February 10, 2004 06:49am
I am in the process of rebuilding my half bath and i am planning to install wainscoting. Would it be okay to use MDF instead of pine? The wainscoting will be painted and i think the MDF would have a smoother finish, however i am concerned about the possibility of swelling if the MDF got wet.
  1. jimmydean | Feb 10, 2004 06:56am | #1
    I gues a lot would depend on what kind of water issues your worried about.
    Do you have small kids who take baths?
    Do you have a good exhaust fan?
    Is the floor heated?
    Is their forced air heating?  Is it a ceiling register or a low wall or a floor register?
    Are you thinking of going around the bathtub too (probably not a good idea)?
    Are the walls both interior and exterior well insulated?
    If you have good heating, it is well insulated, and there is not going to be water on the walls and floors from splashing you might get away with it, otherwise.....
    1. MSA1 | Feb 10, 2004 07:03am | #2
      Well, I do have three kids but its a half bath(no bath or shower). I personally dont think it would be very wet in there at all. BTW its forced air toe kick register no exhaust fan but there is a window.
  2. geoffhazel | Feb 10, 2004 08:21am | #3
    It seems like wherever I have mdf in a bath, water finds it and it swells.  I avoid it whenever I can in wet or damp areas.
  3. MojoMan | Feb 10, 2004 05:02pm | #4
    I would try to keep the MDF off the floor a half inch or so (Cover the gap with base molding) so it doesn't wick water from the floor. Prime the ends.
    Al Mollitor, Sharon MA
    Mongo | Feb 10, 2004 05:34pm | #5
    In a half-bath I think you'd be fine. I'd encourage you, however, to use a good oil-based primer on the mdf. For paint, I still would prefer an oil, though you could use latex.
    I would use something else as the baseboard, though. Poplar. Poplar is easy on the pocketbook, mills well, takes paint well, etc. I combine poplar for stiles and rails and mdf for panels quite often when doing raised or flat panel wainscotting.
    This way, as was previously posted, if the floor does get wet, it'll be something other than mdf getting wet.
    Regarding the smooth finish, you can get comparable finishes on either material if you scuff sand, then tack cloth, after priming and after applying the first coat of paint.
    1. MSA1 | Feb 10, 2004 08:07pm | #6
      Thanks for the advise. I think i'll try the MDF for the base and the poplar stiles idea.
        Mongo | Feb 10, 2004 08:23pm | #7
        Just to clarify...
        DON'T use MDF for the baseboard.
        Edited 2/10/2004 12:24:38 PM ET by Mongo
        1. AndyEngel | Feb 11, 2004 12:15am | #8
          I just bought some rough poplar yesterday -- $1.42/bf. That's cheap enough.Arguing with a Breaktimer is like mud-wrestling a pig -- Sooner or later you find out the pig loves it.
            Mongo | Feb 11, 2004 12:28am | #9
            Excellent price! I'm 8-20 cents a bf more, depending on the quantity bought.
          2. AndyEngel | Feb 11, 2004 01:27am | #11
            Kellogg Hardwood in Bethel. That's a ways for you to go though. 5/4 was $.03 more.Arguing with a Breaktimer is like mud-wrestling a pig -- Sooner or later you find out the pig loves it.
    JeffBuck | Feb 11, 2004 12:39am | #10
    MDF could be used ... if primed .. painted ... back primed ... and held off the floor .. as all others here have said. And ... once again ... Mongo said NO MDF as the base!
    If it's a smooth finish you are after ... price some finish grade beadboard panels ...
    Oak's usually easy enough to find. The "finish grade" plybead has a much nicer face ... and no "footballs" or patches. A little bit of sanding .. and it's smooth as glass ...
    I don;t install "paint grade" plybead ... whether it's to be stained or painted.
    For what I assume to be a small bath ... the few pennies you are saving by going with MDF don't seem worth it to me...
    penny smart .. pound foolish .. that sorta thing.
    Price it out .... I'd not install the MDF .. save it for the hallway ....
         Artistry in Carpentry
Picture-Perfect Pergola
