Miter saw lasers
PaulGC | Posted in Tools for Home Building on November 8, 2007 06:57am
I’ve had my Dewalt 12″ dual bevel miter saw for a few months now and love it. Today I’m cutting crown for the first time on it. I see Dewalt have lasers for their miter saws and I wondered if I should get one. I think they’d sure be great to have when cutting crown as I can see exactly where the cut will come down across the crown.
Are these lasers any good? Are they accurate? Do they need to be readjusted every once in a while?
Paul
    PaulBinCT | Nov 08, 2007 08:18pm | #1
    I have the old PC "LaserLoc" chop saw and love it, so I tried adding the Irwin laser to my DW SCMS.  Didn't like the Irwin, it induces a wobble in the saw that I found...disconcerting.  Used it once, put it back in the case. If you want it, it's yours for postage.  Just shoot me your address.
    PaulB
  2. LB | Nov 08, 2007 08:34pm | #2
    I think you are referring to the DW718. I have it and like you love it however, the laser is a different story. I have the laser but it is very hard to line up with the kerf and the line projects on only one side of the kerf. I believe the old PC slider (the one Norm uses) has a double laser which shows on both side of the kerf. If you manage to get your laser aligned to the kerf there is no guarantee it will stay that way if you were to move the saw. I use my laser just to get the initial idea however, always verify by lower the blade to the cut line before doing the actual cut.
    LB
    1. ANDYSZ2 | Nov 09, 2007 07:22am | #3
      I have the PC 10" miter saw with the double laser and I love it.
      The saw is light enough to carry around and the double laser is a true benefit.This saw is in my trailer full time and so takes some extreme abuse yet the laser has been very accurate for 3 years straight.
      What i like about a laser is if things aren't perfectly square you can visualize with the laser before you cut. Another plus is you can make a small mark and find it with the laser without having to sight down the blade and you can follow the laser with the cut which is helpful if you have to remove just a hair or notch.
      I haven't used my big Dewalt in 3 years since I got the PC.
      REMODELER/PUNCHOUT SPECIALIST
    Dreamcatcher | Nov 09, 2007 03:03pm | #4
    I've been using the makita SCMS with laser for a while now. I actually don't use the laser very often. I do alot of trimwork so the laser line is just not accurate enough to cut in the 1/64 tolerance range. I do switch it on when cutting things like framing lumber or when trying to match an angle.
    BTW, did a bunch of framing the other day using the laser. I was inside and it was sort of dark. After making a good number of cuts in a row, my eyes started  to ache. Made me wonder if looking at a laser line will ruin my eyes.
    gk
      Huck | Nov 09, 2007 03:18pm | #5
      I bought the bosch 10" scm dual bevel saw, IIRC I paid $50 extra for the model with laser.  Once I read the warnings on the laser package, I didn't want to put it on.  Never have, in fact.View Image â€œGood work costs much more than poor imitation or factory product” – Charles GreeneCaliforniaRemodelingContractor.com
  4. JulianTracy | Nov 09, 2007 06:45pm | #6
    I have the 718, and the laser that mounts to it.
    Although it's a royal pain to setup, once done - it's very helpful.
    I was starting a staircase job and took the time to set the laser perfect and I'll have to admit that it really helped in quite a few situations and I used it every single time - very accurate.
    BUT, like was said above - you move the saw a few times and the laser gets offtrack and I still haven't taken the time to get it back on track.
    If I was starting a large trim job, I'd take the 10 minutes needed to set it up perfect and use it, but for regular Ole jobs, I'll probably not bother.
    Is it worth $69 - I'd say probably not, but I paid $28 for mine when HD screwed it up one day and it was definately worth that.
    JT
  5. RRav | Nov 09, 2007 11:35pm | #7
    Anything wrong with a sharp pencil, and a framing square?
    1. reinvent | Nov 10, 2007 03:08am | #8
      Yeah, they are not as cool.
A Practical Perfect Wall
  • The New Old Colonial
