when i shut off my cold water faucet (1st. flr.),i get a moaning sound from the pipes,sometimes it happen’s when the toilet is flushed also.these are both on the 1st . floor.sometimes i’ll get the same sound when the 2nd. flr . shower is shut off. i’m thinking air must be in the system.any idea’s on how to check this noise. thanks george
it's usually pipes rubbing against wood. Trace the pipes and see where the rubbing is coming from. Then slide some plastic around the pipe whereever it rubs and the moaning should go away..
However you need to wait untill friday..
Nice scary sound for holloween <grin>
The sound usually comes from the toilet valve. To test it, lightly press in the float, it should then make the same noise. Pressing it down into the water and let it pop up will not produce the same noise.
Getting a new Fluid Master will solve the problem.
Definitely a toilet valve.
I get the moaning sound only when I flush the toilet and when the water to the toilet has just stopped running. I was also thinking this was air in the pipes, because if I turn on the cold water to the sink the sound stops or does not make the sound if I turn the sink on prior to the sound. You can feel the vibration in the facet handle.
It's resonance in the plumbing, with the toilet valve serving as the "lips" of the whistle. Running the cold water reduces the pressure and introduces some damping.
