modifying bath fan vent duct size
barshfield | Posted in General Discussion on May 6, 2013 09:36am
I am replacing my bath fan.  The outlet of the fan is nominal 4:” (actual 3.75″) and the vent duct to which it is supposed to connect is nominal 3.5″ (actual 3.25″).  Do I 1) get an adapter of some sort (and, if so, where)?  2) slice up the end of the duct to fit over the fan outlet and then use more duct tape than it would otherwise deserve? or 3) do something else?  Thanks, Mark
  1. DanH | May 06, 2013 10:03pm | #1
    If possible find an adapter, but with the expanding aluminum (almost foil) duct material it's fairly easy to "gather" the duct arond a smaller one, with a "hose clamp".
    1. barshfield | May 06, 2013 10:17pm | #2
      the duct is smaller than the outlet of the fan, which means I need to expand the duct or find an adapter. Or something else.  I'm reluctant to go slicing into the flexible duct, just to make it bigger to surround the outlet.  But that might be my first and best shot at it.
      1. DanH | May 07, 2013 06:18am | #3
        I was thinking a short piece of the expandable stuff in the larger size, scrunched down on one end.
      2. calvin | May 07, 2013 06:18am | #4
        Barsh
        There is available in most places that sell fans, a plastic reducer fitting.
        or
        An HVAC supply should be able to give you one in galvanized.
        They'll call it a 4 to 3", but it will allow you to fit over it.  I'd use the alum. foil tape for all connections.  Peel and stick paper backing, also available from the above suppliers.
        1. Mathewtaylor | Jul 08, 2013 12:28am | #5
          Get the other Fan
          As you explained that your duct is smaller than fan so in my opinion you should expand the duct and if you cannot do so get the smaller fan for duct because no other option is there.
          1. calvin | Jul 08, 2013 06:37am | #6
            Mt
            You'd best read the thread again.
            It's not my fan.
            There is another option w/o replacing the fan-4" to 3" reducer.
Choosing a Paintbrush
  • The New Old Colonial
