modifying terra cotta thimble
Rebob808 | Posted in Energy, Heating & Insulation on February 29, 2008 08:31am
Opened up the wall in the bathroom remodel (where there was an obvious bulge and crack in the old plaster) and I find an old thimble from the chimney – which is still in use to vent exhaust from the boiler – in the wall, stuffed with some kind of plaster or mortar.  The thimble extends further into the room than I want to build out the wall, so I’d like to trim maybe an inch from the tile thimble.  Any suggestions as to the tool or technique?  Grinder? Saw?
And what can I use to re-stuff the thimble so exhaust gas doesn’t leak into the wall cavity?
Thanks for any help.
Bob
    McDesign | Feb 29, 2008 08:35pm | #1
    I'd just break it off carefully around with a hammer (tapping inward) and then patch it with hyraulic (non-shrinking) cement from the little pail.  Don't think it's hot enough for refractory cement, and this will seal better.
    Forrest - ready to get flamed
    1. Rebob808 | Feb 29, 2008 08:50pm | #2
      No, heat doesn't seem to be a concern.  I've got it covered with a double layer of duct tape, and it doesn't seem to get hot when the boiler's running.
      You don't have to provide some controlled break point on the thing before starting chipping away?  I sure don't want to have to do a mojor chimney repair on the other side of the wall ...
      Thanks for the info.
  2. dovetail97128 | Feb 29, 2008 08:59pm | #3
    Diomand blade on a peanut grinder.
    1. Rebob808 | Feb 29, 2008 11:11pm | #6
      Alright, I'll bite... what's a peanut grinder?
      1. dovetail97128 | Mar 01, 2008 12:31am | #7
        Sorry , "peanut grinder" is slang for a 4"-4 1/2" grinder. With the diamond blade you can cut stone, terracotta, brick, concrete, tile etc.
        1. mike_maines | Mar 01, 2008 03:34am | #8
          Never heard it called that.  Does it grind peanuts too?
          1. dovetail97128 | Mar 01, 2008 04:13am | #9
            Probably , I am not sure which blade recommend for that job however . I picked up using the term from welders and steel fab shop people working on my jobs. I would guess it is a term used to differentiate between the larger and smaller grinders. On the other hand a lot of those guys were from Georgia and Alabama, guess it could have been called a goober grinder . ;-0
  3. theslateman | Feb 29, 2008 10:56pm | #4
    Take it out and re brick it in so there is no chance of flue gasses or smoke ever entering the home.
    Sphere | Feb 29, 2008 11:07pm | #5
    Structo-lite is a pearlited plaster and fluffy enough to fill a void as such. You'd want a brick or such to take up the major space.
  • Wire- and Finger-Safe Cable Stripper
  • Two Ways to Test Windows
  • Seating and Storage for Any Space
  • Stucco Done Right
