Moen Posi-temp control
Hubedube | Posted in Energy, Heating & Insulation on October 2, 2004 05:25am
 We have a Moen Posi-temp  Temperature control located in a shower stall.  It will control the temperature very good, but you cannot cut down on the volume coming out of the shower head. (its either on or its off)
 I would like to cut down on the volume (probably to half) by adding a adjusting valve just before the shower head, or install a valve on the each of the supply pipes coming in that feed the control.
Does anyone know if this will effect the temp control (cartridge) in any adverse way.? Thanks
