More Junction Box Fun
corrib | Posted in General Discussion on April 5, 2007 04:40am
Photos of my bar are coming soon, I know I’ve been threatening them for a while.
Anyway, I’m still thinking about how to fix my lighting problem.
The situation:
Significant other says she wants one can light controlled by a more accesible switch. Normally, I would have argued, but she caught me at a weak moment (she got a new cordless drill and a bottle of Jameson’s for me, to be used individually of course) and I relented.
Anyway, the can light in question has a j-box that’s full. To connect it to the other bank of lights, I need space in the box for the new wire and I need to keep the splices that are currently in the box for the rest of the circuit.
Options I’ve thought of:
1. A little sawzall remodeling by removing the new work can light and customizing an old work can with a larger j-box for all the wires. (This is all on the same circuit, just different switches.)
2. The existing wires in the j-box are short, but I “might” be able to get them into a smaller, seperate box.  The issue of j-box accesibility from my last post exists here, but from what everybody said it should be okay.
 If anybody has other thoughts, I would certainly be interested. I’d probably even share a little Jameson…
Thanks for helping me win a few “points”.
Patrick
Edited 4/5/2007 9:41 am ET by Corrib
  1. JulianTracy | Apr 05, 2007 06:57pm | #1
    How full is full? How many wires going into the box.
    The 6" fixtures have pretty good size boxes on them.
    JT
    1. corrib | Apr 05, 2007 07:56pm | #3
      2 14/3's right now and I will need to add one 14/2. I'm not exactly of actual cubic inches of the box. On these can lights, it's not huge, maybe 6" wide by 2 1/2 deep.
      I think adding the 14/2 might be a fill violation.
      I've got the space for box extenders, but I've never seen any would attach to these boxes, rectangle shaped.
      Thanks for the responses so far.
      1. JulianTracy | Apr 05, 2007 08:05pm | #4
        Seems to me, unless you have a whole lot of extra wire length from the (2) 14-3's, there should be no problem with one more 14-2 added to the mix.I'm no electrician, but have wired a ton of can lights, and there's more room in that junction box than most wall extended boxes, and I don't think your anywhere close to having it filled to code capacity.Jeez - those boxes have 3-4 spots for cable clamps at least...Just added: my catalog for a 6" can fixture shows specs that rate the junction box as capable of having eight (4in - 4out) 12AWG wiring. You're using 14AWG and only have 6 as of now.JT
        Edited 4/5/2007 1:08 pm ET by JulianTracy
      2. MikeHennessy | Apr 09, 2007 10:33pm | #5
        I just passed an electrical rough-in with (3) 12/2s in several can j-boxes. Don't see why it would be a problem for you. It's a bit tight, but do-able.
        Mike HennessyPittsburgh, PA
  2. grpphoto | Apr 05, 2007 07:33pm | #2
    Would a box extender fit on one of these?
    George Patterson, Patterson Handyman Service
A New Approach to Foundations
