We have noticed the mortar failing mostly at the front of the house along side the small covered front porch. We called in a brick mason to see if he could fix it and all he said was the type of pointing used for the mortar. The sand is continuously coming up and the mortar keeps falling off at the junction. Is there a way to stop the damage? What type of expert should we call to fix this and other issues with the mortar (cracking, falling out). The home is 50 years old btw.
Patrick chats with the BS* + Beer crew at this year's International Builders' Show.
I don’t mean to be flippant but look for a real mason. Perhaps even one that might be familiar with brick and mortar used in the area. The good luck part comes in when whomever you choose does the repair and no one knows he’s been there.
Best of luck!
Edit: another thought. This worked for me. If you have a local trade school or are high school career school, stop and speak with an instructor.
Or perhaps a real brick and block yard. They usually know who knows what and who pays their bill.
I used to be a mason. If you add some pictures and clarify your climate, I maybe can give you some input. In general, you'll need to grind out anything loose or cracked and point it. Softer mortar is typically better (type N), but you should get someone to actually inspect it.
