Mstr Bath Over Garage-N.E.
Belstar | Posted in General Discussion on August 3, 2006 07:40am
I am contracting a 2,900 2-story home this fall in the Northeast (Buffalo,NY).  The design calls for the master bath to be located over the attached garage (relocating is not an option). Besides extra insulation in the garage ceiling, what options do I have to keep the pipes from freezing and floor comfortable.
 I have had two suggestions so far; the 1st is installing a mini-furnace in the corner of the garage, and the 2nd is run a supply line( no return) under the master bath floor from the main furnace (Forced air). Does anyone have any opinions?  I am looking for a solution that make the most economic and functional sense.
  1. paul42 | Aug 03, 2006 08:03pm | #1
    Add some insulation to the garage.  If it stays above freezing in the garage, you won't have any frozen pipes.
  2. MojoMan | Aug 03, 2006 08:37pm | #2
    I would never want to design something in this day and age that required energy simply to prevent frozen pipes.
    Can you run the supply lines through the walls of the conditioned space? Insulate thoroughly below the drains lines. The traps might be most at risk because water stands in them. Don't insulate on top of the pipes so they get some heat from above. Maybe you could use I-joists to get an extra-deep floor frame and insulate with blown cellulose.
    Al Mollitor, Sharon MA
    http://moosehilljournal.blogspot.com/
  3. HammerHarry | Aug 03, 2006 10:09pm | #3
    We have a house where the master closet and master bath are above the garage; the garage is not heated.  It's an R2000 house, in eastern Canada, so the walls are 2x6, fiberglass insulation, and there's an inch of foam insulation on the outside of the walls.  It hits -30C here in the winter frequently.  Floors are warm, pipes never freeze.
    I'm not sure what you expect the problems to be, if you build the house properly.  Put the water and drain lines in the wall between the house and the garage, if they run through the garage ceiling, that's fine, too.  Keep them to the warm side as much as possible (ie, keep them relatively high in the joist bays).  Insulate properly, vapour barrier, sealed well to prevent air infiltration.  No worries.
  4. FHB Editor
    JFink | Aug 04, 2006 10:57pm | #4
    Good topic - bump
    Justin Fink - FHB Editorial
    Your Friendly Neighborhood Moderator
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
