Need a finished concrete expert
| Posted in General Discussion on October 4, 2000 02:17am
I have recently taken over a project that has architectual concrete finished walls both interior and exterior, some of them over 40 foot high! My problem is that the previous contractor did not protect them between pours and the are badly stained, have exposed aggregate and are generally not to the owners liking. The form work was done to provide a high gloss slick finish. Every method I use to try to clean the walls removes this gloss. Any thoughts on patch work and reappling a high gloss finish would be great.
  1. Guest_ | Sep 27, 2000 07:58pm | #1
    Oh boy, Ron.
    The high gloss is the problem that will give you the most grief.
    You can fill in the voids with epoxy filler and rub down the rough spots, but you will loose the shine.
    You can apply a clear sealer over everything but if you have oil stains, it will end up blotchy as well. You would have to clean the entire surface first before putting on any sealers.
    You will have to try a little area first. Concrete varies tremendously and what works here may not work there, if you understand what I'm saying.
    Gabe
    1. Guest_ | Sep 30, 2000 04:23am | #2
      *will they pay for or be pleased with a stone or brick type wall. I dont know how high they can go but i know of stone fireplaces over 30' high installed vertically. Seems to me the best solution would be to cover with a non structural material for cosmetic purposes.....what about furring and installing drywall or paneling......is the concrete being exposed an absolute must?
  2. Cristof_Eigelberger | Oct 04, 2000 04:41am | #3
    I have a residential project using a post-tensioned high strength concrete floor. The concrete floor was to be a finished floor but unfortunately it got screwed up. I am having the contractor pour a new 2" level slab on top of the old. What is the best way to prevent cracking? Should the new slab be glued or floated(allow so the slabs don't bond together as suggested by the sub) on the existing slab?
  3. Guest_ | Oct 04, 2000 01:40pm | #4
    You should use a latex bonding agent between the two. Match the control joints as well.
    Gabe
    1. Guest_ | Oct 04, 2000 02:17pm | #6
      *Make sure the post-tension design is capable of carrying 2 more inches of concrete plus the original design loads. It will also make a difference if the slab is bonded to the old slab (effectively becoming part of the post-tensioned slab) or unbonded (dead load on original slab). Time to call an engineer.Eric
  4. Ron_Amass | Oct 04, 2000 02:17pm | #5
Wiring for Subpanels: The Right Cables
When running cable to a subpanel for a home addition, pay attention to the size of the wire and the amperage of the breaker.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
