I have a sloped gypsum board ceiling (2:12) with a circular concrete column running through it. I need a metal trim for the edge of the gypboard where the column goes through. Can’t use a conventional Fry or Gordon column ring, because the slope changes the circular opening into an ellipse. Anyone know of a metal edge bead (J or L) that can be curved?
Thanks!
Don't know of a curvable metal trim......
do know about vinyl trims made specifically for curvey purposes.
Or, you could probably make your own out of StraitFlex tape with some relief cuts added to help the cause along.
Even my local HD carries both.
Jim
Vinyl L bead
http://www.trim-tex.com/j&lbeads.htm
Mike
Small wheel turn by the fire and rod, big wheel turn by the grace of god.
