Need help on the basics of p-lam coun…
| Posted in General Discussion on February 2, 2001 05:17am
I’m attempting my first p-lam counter & need some help. I understand the basics of using a particleboard base & contact cement to put the laminate down.
Q1 – What prevents water from getting behind the laminate? Seems to me that joints and edges would be likely to wick up water (particleboard’s worst enemy). How do I prevent this (other than minimizing the number of edges)?
Q2 – Is particleboard the best base? 2 layers of 5/8″ adequate?
Q3 – Should I be using a router to trim the edges nice and neat? Can you also file the stuff?
Q4 – Any other tips for making the job come out nicely?
Thanks to all who help out.
  1. J._Belcher | Feb 02, 2001 05:17am | #1
    I'm attempting my first p-lam counter & need some help. I understand the basics of using a particleboard base & contact cement to put the laminate down.
    Q1 - What prevents water from getting behind the laminate? Seems to me that joints and edges would be likely to wick up water (particleboard's worst enemy). How do I prevent this (other than minimizing the number of edges)?
    Q2 - Is particleboard the best base? 2 layers of 5/8" adequate?
    Q3 - Should I be using a router to trim the edges nice and neat? Can you also file the stuff?
    Q4 - Any other tips for making the job come out nicely?
