im an electrician in pa. working in a high end mansion and the owner chose an interesting exterior wood i have never seen for the windows, doors, and eaves, etc. its a very dark wood with copper in it (so its been explained to me). can anyone give any details on this ?
Is that that new wire and wood in one stuff?
J/K I was just giving you a bump to see if any other might know cause ya got me stumped.
Welcome to BT--Did ya bring any brownies?
Have fun and stay a while--ya'll like it Mike
Adam Savage---Mythbusters
Copper has been used as a wood treatment for quite a while. The old pressure treated lumber contained arsenic as well as copper. It was CCA for chromated copper arsenate. The newer types are ACQ for alkaline copper quaternary or CA for copper azole. Some go under name brands like Naturewood.
The newer lumber requires hot dipped galvanized fasteners or stainless steel. Electro coated and aluminum won't last. There is still some debate about whether the new products are any friendlier to the environment. I wouldn't worry about it giving you a shock unless it was wet.
hexy....
do you mean the tree leaches the copper out of the soil and it becomes part of the wood ?
it sounds similar to cypress, which actually leaches fine silica sand out of the soil and it mixes in with the cellular structure of the wood.
your example sounds a lot like Ironwood.. which i think is a brazilian species
